I came across a place that sells a ton of high end turboes dual ball bearing and i saw a gt2510 and got thinkin. My plan which i already have a turbo and z32 MAF for will probably spool at 4500rpm (to4e). I recall many bashings over the past year of guys making and or thinking of running twin gtr or rb20 turboes on an rb20 with absolutely no good news other then the novelty of it. Literally double the rpm to make boost was hammered in as fact. But what about turboes small enough and free moving enough to make it finally make sense(or in the ballpark).
I know theirs a gigantic bullsh1t factor in doing an install like that but how bad would it really be considering how sluggish a to4e will be comming onto boost. I enjoy doing things differently and making whatever i do work out better in the end modified. Twin tiny dual ball bearing garretts must at the very least give more torque sooner, thoes twins maxed right out should only push 500bhp max maybe a bit more or less. A gt3076r would be ideal but is their any love out their for a set of scooter worthy twins??????
o yea, i run an 8000rpm redline
Edited by LedZepLen
https://www.sau.com.au/forums/topic/249943-twin-dbb-gt2510r-rb20/
Twin turbos on a rb20 has been done once here...can't remember who it was though...results weren't the best but then again the setup wasn't right and was far from optimized...i'm a 20 fan too and used to run one...personally...even though it would be a cool project...you're better off slapping on a medium sized single and live with the lack of down low response...even with the smallest of the BB turbos a rb20 will still be lacklustre till about 3000-3500rpm...so if its never gonna be good down low then make sure it sings up high...
Or go 2JZ like i have... :P
Dual BB GT30 on a rb20 sings like a bitch - 235kw at 15psi, just takes 4400rpm to hit it. Pants meter off the charts - hits 180 from 120 in seconds...
Down low, the humble GTS keeps up - on boost its wild
Nothing wrong with lag, worse is blowing your full load of spool too soon
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
