Hey guys i just got home friday night from O.s in Japan, the Next day i was moving into my new house, i was driving along stud road with my g.f following behing in her car and suddenly a black SS cut her off to get behing me and a second later the red and blue flashing lights came on, i was strait away told to lift the hood( no breath test nothing) The police (Pettet of Knox station) told me i couldnt have my intercooler bleed valve pod etc etc. He gave me a minor defect and told me i have to get a enginearing certificate to certify the hole that the intercooler piping goes through and gave me 8 days to fix it (merry christmas)
can someone please explain what i have to get done to certify this.
I am hoping i dont need to put the stock cooler on and plug up the hole?
Has this happned to anyone else and what did you have to do to fix it?
thanks Ben
https://www.sau.com.au/forums/topic/249946-defected-on-stud-road/
  • Replies 57
Pettet knows his stuff and has a reputation for targetting imports.
You are not able to make holes in the body of the car for piping. They will need to be repaired (covered/filled) for it to be satisfactory to the best of my knowledge. I suggest reading through the EPA thread as i'm sure this must have been covered before. My recommendation would be to get it to an engineer quick. You'll most likely have to remove the intercooler you are using unless you can get some custom piping to connect it another way.
As far as I was aware you can make holes so long as they are not structurally damaging hence the need for the Engineers cert. probably cost you a hundred bucks or there abouts to get it checked but good luck finding an auto engineer that is still open for business now. BUMMER!!
They only bring him out for special occasions.
Holes shouldn't have to be covered up, if it is decreasing the structural integrity you need someone to secure a steel plate around the hole to return it to how it was.
As for the other stuff your state differs to mine.
How nice of him to do this before Chrissy! Hopefully an engineer is working through it
Its going to be a pain. When my last car got defected, including the fine for illegal mods and the engineers certificate it cost just over $700. Back then (2004/5) the hole was ok and the engineer had no problems giving it the thumbs up. But now i hear you actually have to cover it up
i got done by that ass face too
i have to get a vass certificate, go for an epa test, not just the exhaust test (my exhaust is stock) get a rwc and also pay the fines
i dun mind paying its just time consuming
pettet ur really earning your 20k a year arnt you
LMAO
I was under the belief that in the series two r33 having the whole cut (if it is where I presume it is) was illegal because it effected the air bag sensor or something along those lines however it wasnt a problem if it was a series 1?? anyone care to expand on that probable useless information that I have...eventhough its probably too late for me now since I've cut the hole already.
Sounds right Zorb, remember hearing that too.
I think I must have been the only person Peteet didnt nail too bad. I only copped an EPA from him. However it was supposed to be a full test but he only submitted the option for exhaust noise.
There is a thread on the hole cutting. Do a search mate, its in this section and has all the info you need
Basically...
If your car came FACTORY with an airbag - he is right.
If your car came FACTORY without an airbag - he is wrong, so take him to court. I would and you'll win.
But find the thread and read it, if you cant PM me and ill have a go at it over the next couple of days
If the pic in your avatar is your car then the cooler hole should be fine since yours is a series 1, as for the bleed valve, im assuming that is a boost controller, very easy to remove for an rwc, the front mount plus pod is something everyone either knows about or should know about, only 1 inlet mod allowed in vic, so either you have to put the standard intercooler back on and keep your pod or put a factory airbox in and keep your front mount, and unless you making good power or want the wank factor of the induction noise an airbox with a good panel filter does the same as a pod any way.
Edited by W0rp3D
he's just doing his job.
i got sent to the EPA ONE DAY after picking up the car from a respray, new turbos, tune etc etc... he wasn't an arsehole, nor was I, but legally, he was right - i went to the EPA and sorted it.
yes, he does a lot of skylines, but he also does a LOT of shitboxes too - I was having a chat with him. There is no "shitboxesaustralia" so you don't hear about him getting these wheezers off the road!
    • Rear doors central locking wiring removed and cleaned. See the first 8sec video of when it’s filled with river silt. its a snip of what I’m up against. front and rear doors complete now. Maybe another day removing carpet and bits and pieces. Then the re assembly begins. 🤙 att.DqweJqhY5MZiZYQDVMhn3LtvdD1RBZ7TBG4f2s7W1zM.mp4 att.lFuN22MZEowqCbFAXoDw009r2gHL76ChMVfxMfBX-uk.mp4
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
