Hi all,
Have installed an alarm in my r33, but cannot for the life of me figure out which wires are for the door lock/unlock.
Can anyone point out where these wires are, and what colours i should be looking for?
Thanks guys!
Ryan
https://www.sau.com.au/forums/topic/249965-r33-alarm-install/
Thanks for that mate, where can i get actuators from?
Do i need one for drivers and passenger side, or will the drivers side automatically unlock the passenger side as it usually does when i unlock with the key?
Thanks, sorry for my newbie questions!
Ryan
Hi Mate,
I go away to work on the 4th of Jan, do you know where else i can get one?
Heres another one for ya... my alarm automatically arms after 30 sec, is there a way to connect the alarm to my turbo timer so that after the car turns off, it arms automatically?
Otherwise, is there a way to wire the alarm so that it can be armed while the engine is still running?
Thanks
Ryan
Hi guys,
Have bought an actuator... now i cant figure out how to wire the thing in? My instruction booklet is crap, so thats no help. Anyone done this before on an R33?
Do i need a central locking control unit as well as the actuator, or just an actuator on its own?
Cheers
Ryan
Hi guys,
Cheers
Ryan
You need a twin relay setup. Purchase a changeover relay from dick smith, autobarn, etc.
Relays
30 goes to green wire of actuator
87A goes to earth
87 goes to 12V source
86 goes to 12V source
85 goes to negative trigger from your alarm (unlock signal)
For the second relay, connect all the same except to 30 connect the blue wire from the actuator and to 85 connect the negative trigger from your alarm (lock signal)
If you have any trouble, call us on 1300 132 893. We come out on-site.
  • 3 weeks later...
Hi guys,
Cheers
Ryan
Even easier, Mongoose has the central locking relays built in on the M80 series. Here is what to do.
Purple + Orange wires connect to 12v Constant Power
Brown + White wires connect to Constant Earth
Then run your Green + Blue into the door where the central locking actuator is mounted and connect to the Green and Blue wires on the actuator. Arm and disarm the alrm and it should lock and unlock. If its around the wrong way just switch the green and blue wire around at the actuator it will reverse the signal for you :)
Oh and on the 1993 Skyline there is a small gromet that you can push the wires through just behind the main grommet of the wiring going into the door, should make the running of the wire easier.
Regards,
Daniel Gardener
Platinum Car Security
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
