Thanks mate, I normally stop at Gundagai for the night whenever I head up for this or WSID meets, done it a few times now, the return trip isn't too bad in one stint at night because the roads are quiet.
No dramas mate. Keep an eye out for animals though, i do that trip very often and theres heaps of them in certain areas - ive found though, that if you can leave Sydney around 7pm and stick to the speed limit (only stopping for petrol) you'll miss the bad spots as they only come out at certain times at night. A few weeks ago i hit a wallaby/kangaroo out the front of the servo as you come into Melbourne where the roadworks are but i was delayed came came through there about 30mins before dawn, its all in the timing :bunny:
  • Replies 86
Posted Images
No dramas mate. Keep an eye out for animals though, i do that trip very often and theres heaps of them in certain areas - ive found though, that if you can leave Sydney around 7pm and stick to the speed limit (only stopping for petrol) you'll miss the bad spots as they only come out at certain times at night. A few weeks ago i hit a wallaby/kangaroo out the front of the servo as you come into Melbourne where the roadworks are but i was delayed came came through there about 30mins before dawn, its all in the timing :)
Yeah thats true. Thanks for the advice. Last time took about just over 8 hours to get home from the track (only stopping for fuel).
So I've entered. Looking forward to it. At this stage I'm going with a crew of 4. Going up sat and coming back monday. Staying in campbelltown both nights.
Same here iam staying in campbelltown at the Rydges.
Flying up on saturday and flying back on the monday.
Guys dont forget, click the link in my sig for cheap tickets and access to the corporate box SAUNSW has organised ;)
(wristbands for access to corporate box will be in the same package as the envelope waiting at the front gate)
I had to choose between Compak Attak at WSID this weekend or Superlap, but I've decided to stick with going up to check Superlap out. Will be cheering on the Vic guys!
Good choice!
Are those tickets just for people going to watch?
I've got 30 more kw's now. Making 230 but only up to about 6500-7000 then it drops off. Looking forward to the extra torque that we made though. Car is almost prepped with only a few things left.
Can't wait!
Changed my mind and decided to fly up for the day rather than drive.
Also will be taking pics for www.fullboost.com.au from the event :D
Ben thats all right, does that mean you get better acess all area's.
Flying up is more likely cheaper this days then driveing, Might see you at the airport.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
