Bump for a great thread!
I just got mine done today and as follows
gts-t
f/r - 245/45/17 ku36
Purpose - touge mainly then street but with compromise for tire wear.
Front:
Castor 7 deg
Toe out 1.4mm total (0.7mm per side)
Camber -1.5 deg per side
37psi cold
Rear:
Toe in 1mm (0.5mm per side)
Camber -1.2 deg per side
35psi cold
HKS springs f/r, bilstein shocks valved +25%, stock sways.
Really like how the car drives. Turns in good, very good mid corner front end grip. Rear end is nice and predictable with lots of feedback.
  • 10 months later...
I have been searching for about an hour but the only info i can find for factory wheel alignment specifications are for R32GTR/R34 Service Manual as per attached image i made, does any one know what the standard wheel alignment specs are for an R34 GTR V-Spec?
Too much negative camber on the rear -1 is plenty
You also have basicly no toe on the rear. Toe it in 1mm each side
Front get a set of adjustable upper arms and set the camber to neg 1.5
Toe it out 1.5-2mm each side on the front, you'll notice the turn in will be alot sharper
What would be the perfect setup in wheel alignment for a R33 GTS-T which is mostly used on street , but has good handling & can stick to the road well when u take it for a nice hard drive in the mountains ? What setup would be good with camber front & rear , Toe in , Castor , ect ? This weekend i'm fitting adjustable upper camber arms front & rear , front adjustable tension rod arms & bar , hardened tie rods with KTS tie rod ends , Adjustable rear tow & traction rods aswell . Help with alignment specs would be much appreciated :) Cheers
Edited by Tweaky
  • 1 month later...
any GTR recommendations? recently had one done and the rear end feels super twitchy on sydney roads. looks like a lot of toe in with about -4 camber (camber arms bought already) on the rear and about -2.5 camber and slight toe out on the front. this is from a visual inspection
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
