Mate I sympathise with you being in a small town, been there done that.
My first thought was it sounds like you have an air leak, have you checked right over all your hoses??? Especially the two on the intercooler? They can split under the outter cover and be a royal pain to find.
Can you hear any strange noises? other than the actual engine running poor?
Yep checked them all... did the water trick when it's running, just a thought could it be the timing belt has skiped a tooth? making the time way out?
Ok, so no air leaks. But overfuelling still? Next thing to check is the AFM's.
There are two problems with GTR AFM'S as far as I'm aware.
1: The actual loom connector where it plugs onto the AFM. The pins loose their tension causing various, constant or intermitent problems. I had this, took a little while to track down. It would start running rough, smoking etc, so I could pull over, wriggle the connector and you can hear the engine change note.
These connectors are not available from Nissan, some of the SAU supporters sell them. In my case I was working at an importer at the time, Subaru use the same STYLE connector, so I used better condition pins from a subaru connector and joined into the car's loom. Have done over 30,000km with no problem since.
2: The other problem is under the top cover of the AFM there are solder joints where the pins are soldered. With the weight of the connector on them these can fail. There is a thread on SAU showing how to do this. It is quite simple.
Have a look at these two things before stressing yourself out.
Cheers. can i solder the wires directly to the AFM to test it out? Not wise?
I've actually seen people use individual socket terminals that fit the afm pins then silicon the whole thing up! I personally would never do something like that.
I actually tested mine, I used a couple of paper clips to back probe the afm's with a multimeter when the car was running. My signals were way out of spec, thats what lead me down the afm path.
I cant remember what the specs were and what terminals to test. Its in the workshop manual. I can get it for you tomorrow.
Another thing that can cause similar issues, but it would be constant, is if the fuel pressure reg seized shut, But I'd be checking the AFMs first.
agreed with the self diagnostic check, which is how i knew my AFM were causing an intermitent problem.
do a search and find the link, + a list of the codes.
from memory and this is assuming you have the same single led rear ecu (mines 89')...
remove passenger side kick panel
undo ecu
turn screw on rear of ecu all the way to the right
turn on ignition, wait 2 seconds
turn screw all the way back counter clockwise
the led light on the rear and a light on the dash will flash the code (check with list of codes)
undo ecu
Cheers for that i will try to get to it tonight...
undo ecu
G'day guys. Just wondering if its the same to same on a R32 GTS-t??? Problems with mine.
UPDATE!
I stripped out the AFM meter to start checking them... as i removed the airbox i notice that the twin turbo pipe was semi loose...
BAM
The twin turbo pipe has a little elbo that sits inbetween the turbo inlet and TT pipe, it had cracked in two and was just sitting on there causing the boost leek and really shit performace. Now to find this part....
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
