I was driving home with the wife in the passenger seat, boot full of toys and stuff from shopping, minding my own business driving the 60Km speed limit. The road was slightly wet, due to the rain and there wasn't many cars on the road. by the way i drive a R34 GTT stock.
This is what happened in point form:
1. Driving on punchbowl rd just past intersection of belmore rd, a white R32 GTR with black rims with a red strip on the rims drives near me.
2. The R32 starts to be aggressive in that he's revving the engine wanting to race me.
3. We come up to the coronation pde intersection, the lights just turned yellow. I have the option to:
a - Speed up and beat the lights or
b - be a good citizen and slow down.
4. I chose B as i'm thinking the R32 would speed off but i was wrong, he decides to slow down to.
5. I'm thinking oh crap, he's his chance to show how good his car is against mine (mind you it was a nice looking GTR, but needed a wash).
6. At this time, the R32 was revving like crazy but when the lights went green his car stalled.
7. My wife and I laughed so hard i made sure the guys in the R32 heard us.
8. I drove off like a granny when the lights went. He finally caught up to me while i was turning into burwood rd.
So if you see a white R32 GTR with black rims with a red stripe and a large sticker (of some performance place), point at them and laugh!!!!
P.S if anyone who is on the forums with the above car i'm sorry i laughed so hard.
Edited by Atomnaya
https://www.sau.com.au/forums/topic/249983-funny-thing-happened-tonight/
...............???? and theeeeeeeenn?
Page 4 he's got a triple plate clutch which he's getting used to cos it's new ....page 6 maybe he was like I'll stall and give em a chance page 69 maybe he was habib? And page 25 for he wanted to take your toys =)
Edited by DaGr81
I drive along that road most nights of the week. I do regularly see a white GTR usually parked around near the shops at croydon park, One thing I do know is that that road as it has only just been resurfaced is apparently a bit of a hot spot for late night drag racers of late.Which may explain why he wanted to run you so badly
and then at the lights again........"OMG BRO....im from puncbowl/lakemba.......how dare you laugh at me couz *pulls out a gun*, Wulla...swear to gawd i will shoot you...!!!"
Edited by eeiko321
Lols i live on Punchbowl Road hahaha!
Ive seen that stupid GTR roaming around.. sometimes over does it, makes skylines look bad.
Sorry if your on here dude, but its the truth.. and dont come looking for my house lols!
MRXTCZ
    • Good points thanks. Unfortunately I can't seem to rename this or delete the topic. Seems like I'll ask the moderators to change it or delete it.
    • You might want to update the thread title.  V37 ≠ V36.  And it probably isn't a G37 unless it is 2012+ Ininiti or LHD.
    • Just a basic run down of the relevant bolt-ons. All e85 First graph 406.9whp is HKS GT-RS, HPI manifold, 3" bell mouth dump / 3" straight through fake cat / 3" all the way to the rear and no resonators, nismo 740cc, walbro 460, oem RB26 itb's, power fc, eboost2, Greddy Spec M fmic, poncams, Turbosmart actuator, splitfires, ARD 150amp alternator. Blue line is same as above but Blitz Dual SBC (before i upgraded to eboost2) and 100cell "high flow" cat. Red line is after installing eboost2 and the fake 3" cat (it's just a 3" pipe with a cat shell welded onto it). Huge gains in response, as can be seen. Black dots are a mates sr20 with almost identical setup but uses a garrett 2871 instead oh HKS. Next grapghn 466.6whp is same as above, but HKS 2835 Pro S with the larger .87ar turbine housing, the special HKS Pro S dump pipe into a HPI split dual 2.5" front pipe and the rest stayed as is. Red line is after I welded the actuator brackets. (It was originally bolted together and was moving a couple millimetres under load). Green line is obviously before I welded the bracket, no other changes. 100whp gain at 3750rpm, massive gain for such a simple fix. Third graph is my current setup, huge changes. 469.7whp R31house twin scroll manifold, twin TiAl 38mm gates, Forced Performance (USA) HTA3076 with 1.01ar twin scroll rear housing, Link Fury+ and loom by 12volt, PRP trigger kit and r35 coil kit with r35 splitfire coils, HKS step 1 vct staggered cams, new oem lifters and performance springs, 49mm itb's w/port matched Nismo plenum, twin walbro 460 surge tank setup + 1650cc injectors, HKS Type R S13 600x300x103mm fmic, individual egt's, 4" turbo back with no resonators or cat and AES true straight through muffler + 4" butterfly off the dump pipe lower 90° bend. It's a preliminary tune with no boost control with using 20psi gate springs and 4" butterfly closed. Once body loom and PDM is compete, will go for 30psi tune.
    • Power light apparently functions as a transmission error light, you can try the power sequence to read any codes from the transmission control unit.
