  NRV155 said:
A crazy priced gtst. Did i miss something that justifies the value of this somewhere?
http://www.carsales.com.au/all-cars/privat...id=11E66C73C621
Oh its only a shit box R32 GTS-T.............
lol
"EXTREMELY REGRETFUL SALE " hahahah im sure it is if he does sell it at that price....
ive seen R33 GT-Rs for that price
https://www.sau.com.au/forums/topic/249996-is-this-a-joke/#findComment-4333592
******** EXTREMELY REGRETFUL SALE - FUNDS REQUIRED FOR UNIVERSITY ***********
Lol dumb ass...I have a suspicion she may remain a dumb ass for a long time if she's relying on selling @ that price to fund her education.
Hairdressing university, specializing in fake nail technology perhaps.. :P
https://www.sau.com.au/forums/topic/249996-is-this-a-joke/#findComment-4333684
i rang the mobile number and asked if they had the skyline for sale
the person on the other end sounded grouchy and old
"is that another bloody person off that bloody site"
"yes" i replied
"well the bloody number is wrong, we dont have a bloody car for sale"
i laughed and hung up
https://www.sau.com.au/forums/topic/249996-is-this-a-joke/#findComment-4334298
OMG!!!!!!
this has to be the biggest joke of the millenium
was she repeatedly dropped on her head as a child or sumthing????
so if my calculations are correct my gtr should be worth around the $150- $180,000 mark????
Edited by UWISSH!
https://www.sau.com.au/forums/topic/249996-is-this-a-joke/#findComment-4334773
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
