hi i am new to these forums .i am prepared to offer my services to the members .
i have access to a cnc lathe with live tooling and also a machine centre "mill'.
my proposal is if anyone has any ideas /parts they would like to have cnc machined and there is a interest in it on the forum to make it worth making ,i am prepared to make parts .obviously the person that has the idea will recieve their part for free or for cost of material if it goes to manufacture.
prefer to make cosmetic parts or bolt on like brake res caps /covers etc you may have seen a part for another make/model car or don't know where to buy the part from .no performance parts like turbo bov etc
start sending your ideas
dave
Edited by texasholdem
https://www.sau.com.au/forums/topic/250002-look-cnc-machining-custom-parts/
To be honest, i have done this brake conversion on a car. Its really not a good setup at all, as to make the pad gat close to full contact on the rotor, we had to machine a lot of alloy out of the calliper to suit the different diameter rotor, which is certainly highly illegal , as it weakens the calliper, and even after taking enough metal off the calliper that the bolts holding the two halves of the calliper were exposed, even then the pad hung off the edge of the disc, which obviously isnt good for pad wear and brake performance. Although it seems like a good upgrade, the end result is definately a :laugh: and could never be properly engineered
i have done a few brake conversion kits and wondered how it would go with the extra dia on the disc .
if someone had done it and could supply a sample to copy it would be easier .i dont really want to pull my car apart to jig up a caliper if it isnt a really good conversion .
my wife uses our r34 as a daily so a brake kit is something that would take time .
more interested in making bolt on bits or cosmetic bits .billet strut brace mounts etc would be easier to make . i will have a look over the car the next few days for suggestions and see what ideas i can come up with
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
