someone gets a nose in front on the outside under brakes and you say the corner is lost??? Its the guy on the inside that has the corner mate. The guy on the outside needs to concede, or try and hang tough on the outside and hope the other bloke doesn't muscle him out. But a guy like Alonso isn't going to give you room to pass him on the outside of a corner. Get real.
If Alonso couldn't make it around the corner at that speed how was Weber ever going to do it on the outside at the same speed? It was never going to happen. Its a daft corner with that ripple strip in the middle of the road, but if that's going to be considered the edge of the track, you can't use ground outside the confines of the track to your advantage - ie to overtake someone. Ask Hamilton.
yes ask hamilton, i've seen him do it and get away with it. and i've seen him do it and get penalised. both cases were a bit different to webbers though, he was just run off the road by alonso who out braked himself. if there was grass there and webber had still managed to pass him they probably would have let it stick. the fact that they BOTH went over the ripple strip and 'off the track" in my mind makes it even. pass should have stood.
  • Replies 2.5k
Posted Images
if alonso outbraked himself and Weber was a nose in front, didn't Weber outbrake himself too?
Alonso tried to stay on the track at least. Weber seemed to decide early on it was better for him to get back on the power and run really wide.
Man some of you Webber lovers just can't get past the fact that rules are rules. Niko also broke the rules and had to pay a penalty!
It was a 50:50 call with Webber in my eyes. I was disappointed but i can see why he got the penalty. The only think i ask for is consistancy...how is Kimi driving wide at La Source and KERSing around the outside of everybody is legal! Yet when going wheel to wheel with a car into a braking zone if the car on the inside uses all the track on exit and you run wide to stop a clash then you get penalised....?
that corner would have been so much ballsier and more interesting without that munted ripple strip placed right where you'd normally let the car run out towards the wall.
too much speed off the apex for the regulators to be happy with otherwise, i guess(?)
Ahhh no, its pretty hard to take a corner when there is another car there no?? The position was lost because there's a right hand turn after that corner and webber would've been on the inside for that corner.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
