someone gets a nose in front on the outside under brakes and you say the corner is lost??? Its the guy on the inside that has the corner mate. The guy on the outside needs to concede, or try and hang tough on the outside and hope the other bloke doesn't muscle him out. But a guy like Alonso isn't going to give you room to pass him on the outside of a corner. Get real.
If Alonso couldn't make it around the corner at that speed how was Weber ever going to do it on the outside at the same speed? It was never going to happen. Its a daft corner with that ripple strip in the middle of the road, but if that's going to be considered the edge of the track, you can't use ground outside the confines of the track to your advantage - ie to overtake someone. Ask Hamilton.
yes ask hamilton, i've seen him do it and get away with it. and i've seen him do it and get penalised. both cases were a bit different to webbers though, he was just run off the road by alonso who out braked himself. if there was grass there and webber had still managed to pass him they probably would have let it stick. the fact that they BOTH went over the ripple strip and 'off the track" in my mind makes it even. pass should have stood.
  • Replies 2.5k
Posted Images
if alonso outbraked himself and Weber was a nose in front, didn't Weber outbrake himself too?
Alonso tried to stay on the track at least. Weber seemed to decide early on it was better for him to get back on the power and run really wide.
Man some of you Webber lovers just can't get past the fact that rules are rules. Niko also broke the rules and had to pay a penalty!
It was a 50:50 call with Webber in my eyes. I was disappointed but i can see why he got the penalty. The only think i ask for is consistancy...how is Kimi driving wide at La Source and KERSing around the outside of everybody is legal! Yet when going wheel to wheel with a car into a braking zone if the car on the inside uses all the track on exit and you run wide to stop a clash then you get penalised....?
that corner would have been so much ballsier and more interesting without that munted ripple strip placed right where you'd normally let the car run out towards the wall.
too much speed off the apex for the regulators to be happy with otherwise, i guess(?)
Ahhh no, its pretty hard to take a corner when there is another car there no?? The position was lost because there's a right hand turn after that corner and webber would've been on the inside for that corner.
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
