  • Replies 2.5k
Posted Images
I am sure if Fisi had of been able to test the Ferrari before switching that it may have been a far tougher decision
An opportunity to drive for Ferrari for an Italian and debut for them in Italy..... Fk man I'd literally give up a nut for that :3some:
Kimi has been doing very well lately.
All R&D is for next season and he is still driving the nuts of that thing !
as for MW....no comment
trulli you bad a$$ loll
as for fisi, mate go bury your head into a pizza or something what the hell was going through his mind leaving the pits.....
Seemed like he was riding a pony instead of a prancing horse !!!!
...what was going through his mind leaving the pits.....
That was great. Heiki almost made up for his average performances in McLarens so far with that one move... almost
What's even more hilarious is when he overtakes a Toyota driver on the last corner of the last race to become the WDC, and makes little Brazillian girls go all teary.
Now THAT'S funny :)
I've always wondered how many $millions that cost McLaren last year.... Anyone know?
like some kind of western suburbs crack addict, im having to check planetf1.com a couple times a day, every day, to see if kimi is joining hammo next year
yeah, I was playing that game at work last week. lol
nothing. Toyota's own telemetry shows Glock was going as hard as he could on his dries, and Hamilton just had better pace on inters.
Either way Lewis is a choker lol, chokes on the last lap, chokes in the last 2 races of the season...ROFL
Had Renault not cheated massa would be champ. You all know that...
/end trash talk
btw kimi I think should be at brawn, because jenson sux hard... That makes 2 English chokers...
Okay, let's play that game:
If we go with the 'what if Renault hadn't cheated?' scenario, if Massa had have received a drive-through penalty for driving off down pit lane with the fuel hose (like He should have); then adding the drive through time to the time lost by the pit crew retrieving the busted fuel hose from the car, there is no way He would have finished in the points anyway.
What's more (and worse for Ferrari fans), is that Hamilton started P2. First and second placed Alonso and Rosberg quite clearly benefited from Junior's shifty self-pwnage (they started 15th and 8th respectively). So if Lewis had have finished in P2, He would have collected 2 extra points (or possibly 4) for that race.
So loser-boy finishes the season at Interlagos 3 points (or possibly 5) behind Hamilton, rather than 1
But it still would have been at least 1 point any way you care to slice it :)
Now can all the bleeding-heart Massa fan-bois finally s.t.f.u about this? Probably not I'd suppose, but it'd just be ignorant of the facts to keep crapping on about it...
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
