Garage Sale
PLEASE CALL ME ON 04301 487 92 if u have any questions on any of these parts
all parts are located in NSW fairfield
GT3076R TURBO KIT = $4000
TURBO: GT3076R
*also comes with braided line for oil return*
TURBO: is in very good condition, no oil leaks, no need of rebuild *ready to bolt on*
EXHAUST HOUSING: .78 divided exhaust housing (twin scroll / split pulse)
EXHAUST HOUSING: V BAND flange for dump pipe
EXHAUST HOUSING: ceramic coated
EXHAUST MANIFOLD: exhaust manifold is made from steam pipe and comes with full life time warranty
EXHAUST MANIFOLD: is also design around the SR20 1,3,4,2 firing order. cylinders 1 and 4 are divided from 2 and 3
EXHAUST MANIFOLD: is design to work with a divided twin scroll split pulse exhaust housing
EXHAUST MANIFOLD: ceramic coated
EXTERNAL WASTEGATE: Genuine TiAL 44mm
EXTERNAL WASTEGATE: comes with scream pipe
DUMP PIPE: made to suit V band exhaust housing
DUMP PIPE: made from stainless steel
COMES WITH EVERY THING U SEE IN THIS PICTURE
RB25 gearbox with sr20bellhousing = $3100
comes with one piece tailshaft already modified to suit
comes with gear stick
comes with slave cylinder
basically comes with every thing need
gearbox still in very good condition and very strong not making any funny noise at all
R32 GTR shell, $4000
car is still repairable
damage is done to driver side of car
comes with standard R32 GTR rear end
comes with dash, carpet and all the interior
R32 GTR X-force Cat Back exhaust system = $300
DSC00610.jpg]
R32 GTR front and rear brakes with master cylinder = $1000
front brake pads = VN endless NEW
front brake disc in good condition and does not need any machining at all
rear brake pads standard but dont need replacing as they still have heaps of meat left on them
rear brake disc still in good condition and dont need any machining
IM SORRY BUT I DONT HAVE A PICTURE OF THE BRAKES YET, I DONT WANT TO START STRIPPING THE CAR UNLESS I KNOW IVE GOT THE PARTS SOLD
gizmo shift light (blue) 2 stage shift light = $150
i dont realli have a good picture of this item but u can kinda see it in this picture
its just sitting near my steering wheel
SR20VET cylinder head compete = $2000
VERY VERY VERY RARE
comes with intake and exhaust cams, rocker arms, rocker cover, crank angle sensor, intake and exhaust manifolds basically the whole top half of the engine
SR20V P12 Primera CAM SHAFTS BRAND NEW FROM NISSAN = $700
SR20VE (20V) neo VVL
Intake cam
Low duration: 228deg
Low lift 10.10mm
Low center angle: 114deg
High duration: 278deg
High lift: 12.00 mm
High center angle: 114deg
Exhaust cam
Low duration: 244deg
Low lift: 8.30mm
Low center angle: 106deg
High duration: 280deg
High lift: 11.15mm
High center angle: 108deg
SR20VET bottom end competer = $1500
comes with pistons, rods, crank shaft basically comes with every thing
splitfire coil packs to suit S15 BRAND NEW STILL IN THE BOX NEVA USED = $600
apexi VAFC BRAND NEW STILL IN THE BOX NEVA USED = $400
controls VVL / Vtec
MSD 1000cc top feed injectors = $500
4 injectors
SARD 800cc top feed injectors = $500
4 injectors
bosch 023 fuel pump rated at 700hp = $200
Bride Zeta II bucket seat with rail = $800
Recaro SR3 Passenger & Driver side $1500
Rails suit: R32, R33, R34 GTST and GTR
in very good condition no holes or any thing like that
will modify rails to suit S13/S14/S15 free of charge
Cusco Coil Overs With Swift Springs = $2000
suit R32 and R33
OS GIKEN twin plate clutch = $1000
suit SR20 5 speed gearbox only (suit S13 and S14 gearbox)
not slipping at all and still in very good condition
will work with SR20 bell housing RB25 Gearbox im selling
Power FC D jetro to R32 and R33 GTR RB26 = $1700
comes with all map sensors and harness
these are very rare now
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
