Hi guys,
Just wanting to know if i should be upgrading my injectors for my power goal of 300rwk. Too many different opinions which has got me puzzled.
If i do require injectors what ones will slot into the stock fuel rail?
mod list as follows
-nismo fuel pump (intank)
-stock dumps,
-jjr front pipes, hiflow cat and 3 1/4 catback exhaust.
-wolf 3d ecu v400
-garrett 2860 -7 turbos
-100mm thick fmic which came with the car
Ive tried searching but couldnt find my exact answer.
Thankyou
All I know is from everything I've read on this forum.
I'd say yes, you will need new injectors. 550's should do or 600's would be plenty. Perhaps Nismo, or Sard's would be cheaper.
Have a look in the sticky threads on turbo upgrades. See what people are using appropriate to their power output.
Although U have seen a mates car pump out overr 300 RWKW on stock injectors and fuel pump, I wouldnt encourage it.
700's would be more then enough. Dont go 800 CC Sards, our have to change the plugs for them!
As said in previous post 600 or even 550's would be enough.... Im a man of overkill so hey! :)
Nismo 550/555's, i forget the size but its one of the two
All you need, thats all i have in my draw for when i need em :)
Stock injectors can do it with a FPR but you really do want injectors ideally.
so on stock injectors, what sought of power levels (rwkw) would you not go past.
for in stance, would you be maxing out at 270,280rwkw??
i wouldnt bother pushing them at all just upgrade, i made the mistake pushing mine which ended in disaster 280rwkw bumped up fuel preasure running at around 96% duty on safe tune all sweet untill no.6 injector burst which leaned out the cyl and melted the piston. 700cc +1
i am getting too many mixed opinions on injectors. And im just confused now.
apparently the stock plug needs to be changed if i go the sard 700's?
All i want to know is what injector is an oem replacment between 550cc -700cc.
part numbers etc would be a big help
ty
Edited by R33GOD
can anyone confirm but i read sometime ago, to use the highest flowing injector on the leanest running cylinder?? is that cyl 1 or 6??
anyone know sard 700 latency??
Cyl 6 is the LEASEST cyl.
if you look at the plenum on the rb26 no.6 port it comes in to cater for the clutch booster i think, and causes no.6 to get starved of air or something in hight hp engines, nismo do a replacment bolt on plenum and gready do one to that fix this
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
    • Any damage to the box/input shaft?
    • Hey there Mate , I just got my local guy to install it Waterhouse Performance, Penrith (specialise Nissan/Datsun and other performance cars) , you can do it yourself if you like , AMS has instructions on their website.  Cheers Pac
