not a good night but yeah...need some help ppl.
as the description says...had a bit of an accident.
i need to know who you guys would recommend to get a quote/repair to the damage.
and also insurance wise..i signed up the other day with justcars. but i have not paid it yet as im still waiting for the bill in the mail..so what would happen in this situation?..feedback please guys...i need it:(
merry xmas to everyone too.
https://www.sau.com.au/forums/topic/250147-please-help-need-advice/
Sorry to hear mate..
Insurance should cover you from the date the policy was agreed on. Just make sure you pay it asap.
Has it been reported to police? Insurance will need a police report, to verify when the accident happened, and various details.
It may not be worth claiming though, depending on damage and your excess amounts.
Ring JC and ask, they were very helpful with me everytime I rang with a question.
Hope the rest of your Xmas was merry!!
yeah i was thinking of just fixing it myself so that i dont have any claims marked on my history..but yeah i think i may give damage control a go seeing as it is only the next suberb away...its just come at a bad time for me money wise (like everything else right).
thanks for the help ppl. much app.
with just cars excess being as high as it is
it will probably work out cheaper getting it fixed yourself
depending on how hard you hit the curb you could have bent a number of steering arms/suspension etc etc
take it up to WA suspensions and get them to have a look if anything is bent etc
if its going to cost over say 2/2.5 k to fix then think about making an insurance claim
bit of a bummer about it happening at xmas time but good luck
this happened due to lack of concentration, but im glad i didnt injure any one or damage any property...i have had a look underneath it i can only see one bar that is badly bent..so im hoping its just that for now..i scratched along one of the massive curbs then the front wheel must of smashed sideways on the begining of a new curb just after a storm drain while i was trying to turn away...thats wat i think happen anyways..hmmm..:)
know how you feel man. had this happened to me before but mine was because my tyres were bald, went round the corner when its wet, understeered then hit the kerb pretty hard. when i put it on the hoist, my lower control arm was bent. my wheel which took the hit is damaged as well. put it on the balancing machine you can clearly see it moving around. had a new control arm fitted since, lucky none of the other components were damaged and got a wheel alignment done. wheels still buckeld tho.
i cant remember but the control arm costs close to $300 but that was with trade price and got one of the mechanics at Nissan to install it; getting a mechanic to install it should be around 150 but im not sure on that one. got my wheel alignment done at wa suspensions and that costs bout 90. havent done anything to my rims yet tho. have you checked the rest of the suspension components?
how much did that set you back nick?
Edited by R33_NICK
    • I don't like "actual computers" for in car use. They take time to boot up, have OS annoyances, and so on. Arduinos etc are ready to go a few seconds after power on, don't mind being agressively powere cycled, because everything is non-volatile, don't mind being shaken and stirred.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
    • Being a race car, and being in the era of the Arduino, one would think it would take little effort to build a controller to do the spraying based on a real physical measurment. Waaaaay back in the dim dark AS days, JE "designed" (as in, he had help) a microcontroller based intercooler spray system. It watched the difference between a temp sensor stuck on the core and one in the free air in front of the cooler, and if the temperature difference exceeded a (settable) threshold, it would activate the sprays. Thus, it only ran water when there was an actual need for water. If you stop to think about the actual physical things that are going on in that stack of coolers, there's probably at least a couple of triggering conditions one could come up with, and one could probably even run one pump with more than one solenoid valve, to allow water to be placed where it is needed, or at all points at once (if it is needed at all points). We're in the age of science baby. But.... I suspect that intercooler water sprays are on the forbidden list in most circuit classes, no? So only good for Targa type stuff?
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
