blu plastic stuff... on the back of your metal thing...?
wanna be a bit more descrptive?? :D
You know that big squarish metal thing? lol. The one you have to mount somewhere in your car? Has like all the cables connecting to it. Well on the back of that it had blue plastic stuff. A bit like when you get a new phone, or a new ipod and it has that plastic stuff over the screen. It's a bit like that except this is blue. I left it there but now i'm starting to wonder if its going to just melt when my engine gets hot.
  • Replies 74
Funny you should ask that, i had another person who had a H1 and a H3C bulb in their car.
He ordered 1x H1 BOSCH KIT
1x Pair H3C BOSCH bulbs.
R32Abuser i think his user name was, just ask him.
That was $298.65
Finally got around to install my BOSCH HID kit and charge my battery.
The drivers side is the 6000k bulb and the passenger is 5000k.
Would it be possible if you or other forum members were able to post pics of the light against a wall of the bosch unit? Just curious if there is some sort of cutoff on these units when installed in skylines. Thanks!
IMO these do not glare as much as the cheaper brands because the place in the bulb where the light is created, is further up on the bulb.
That extra 4mm or so makes all the difference.
This means light does not escape around the shield when looking from an angle. Ill post some pics when i get my car on the road.
I tried taking pics of them at night time but i realised my photography skills aren't that flash! It's a lot harder to take decent photos at night with the HID's shining. Ill try to get my mate who has a good camera to take some photos, see how those turn out....
Inline with GB rules about having a start & end date - this is now closed.
http://www.skylinesaustralia.com/forums/Th...Gro-t81129.html
SAU is clamping down on these GB's that never occur, never end, and so on.
PM me if you have a problem. However, before you PM me think about this.
A group buy, is a group of people buying the product together to lower the price.
Buying single units here and there is not what constitutes a GROUP BUY
Thanks
Guest
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
