GTR N1 turbo's 4 sale
I have a pair of N1 gtr turbo's off a r34 gtr! they have hks non turbulaince dump pipes and hks actuators which hold 1.1 bar. these turbo's are twin scroll ball bearing turbo's rated at 350hp each. i will also supply a pair of hks air filtters and ram pods. turbos are in A1 condition. i can ship anywhere at buyers expense. im am askn $4000 and im selling due to turbo upgrade!
Contact by pm or 0403 606 314 Glen....
Originally posted by DoughBoy
The N1's are slightly larger than regular turbos, they have steel wheels and are pretty much a direct comparision to HKS 2530's. Bolt up to standard manifolds/oil + water lines too.
Oh and wtf is a real car Mr. En One?
A real car is a lowered desiel gemini on 13inch steel wheels with monster tacho and shift light............:shake:
casue if you have actually looked beeble and beeble gtr has finished in the top 10 quite a few times and white and whites r34 was comin preety close to the winning one year.
also for the last 5 Years except last year you should have seen a blue r31 gtsR so we do go down there and we kill it ok we get the best performance for the cheapest prices compared to porshe which is he which are like 300 g's + k so if u have entered it and seen what it has done to cars then talk and if not shut up. also just jap and there are heaps more
bye :P
Sorry for the thread hijack 31, but Mr En One - 15 posts and you've done pretty well thus far at pissing everyone off. Try getting a clue for starters, then try reading the forum rules.
Good luck with the sale of the terbs 31 - If I was closer to needing a set myself you'd have a sale.
Jash
 Share
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
    • Finally had some time after working on other projects to jump back on this thing. Pulled all 4 wheels to check the brakes over and lucked out, only needed to bleed them/change fluid to get everything working!    Took it for its first quick spin (around 2km) up the road and ran great! Sounds like I have a left rear wheel bearing that needs replacing and there’s a shake in the steering wheel but the tires are absolutely junk on this thing and had been sitting flat when I went to first look at the car so we’ll see if that’s the cause.   Tach randomly started working but I notice if my hicas light comes on the tach stops working 🙃 yay for electrical gremlins
    • Bunnings car park it is! if you buy the kind of dampers with the adjustable top on the strut you can see it, red, purple? So many options.
