hi guys up for sale i got a damaged gearbox that will suit a rebuild, i think may be good for parts, i was driving this car in my ownership for 3years and just decided to let go on me, 4th gear just started crunching about 2months ago, on high revs 3rd gear would be a problem most of the time, last night went out in the gtr, took off and we snapped in 3rd gear and there was no 3rd then we tried going to 4th there was also no 4th, only gears we used to get home were 1st 2nd and 5th, now just went into the garage and strated the gtr and gearstick is stuck in 3rd gear and doesnt want to come out, gearbox is still in the car so any inspection is welcome, im about to purchase a r33 gtr gearbox for the car so all this would be doing just takiing room and making a mess in the garage
NOTE- GEARBOX WILL NEED A REBUILD OR CAN USE PARTS OT OF IT BUT I DONT SEE WHY YOU WOULD
price $280
located in melbourne northern suburbs
cheers tony
https://www.sau.com.au/forums/topic/250193-r32-gtr-gearbox/
Interested in buying a stuffed box for some parts. cost to freight to brisbane?
hey mate pm me your postcode and i will chase it up for you but i seriously dont think it wil be cheap to send off mate as itrs really heavy, anyway pm me your details and a contact
cheers tony
https://www.sau.com.au/forums/topic/250193-r32-gtr-gearbox/#findComment-4341256
hey guys this gearbos is still available but one of the parts has been taken out and sold sepertaly so will sell the box for $180, and from my mechanics point the folks or something are stuufesd in the box but it is very good to use for parts or to rebuild,
the part that has been sold is the plate that the main shaft goes through and covers the bearings inside the bellhousing, the one that also mounts the pivot bolt or else everything is there
NEED IT GONE
cheer tony
Edited by GTRBOS
https://www.sau.com.au/forums/topic/250193-r32-gtr-gearbox/#findComment-4360284
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
