Hey guys, i just came to QLD and got a r33 s2 gtst. Would like to know where i could get parts from, like bov's , coilover's, and other stuff.
Also, intending to keep the stock turbo, what upgrades would you guys recommend? And what can i do about the speed limiter on the r33.
Thanks for the help, as its the first skyline ive got so far. Had troubles going around looking for a bov and a suitable gadget to solve the speed limiter. Would a SAFC or RSM be good enough?
Thanks alot!!!
https://www.sau.com.au/forums/topic/250199-r33-gtst/
check out the traders on this site in the main classified sections. lots of parts for sale through them.
also go read in the other sections on mods etc there are lots of threads on this site covering mods and after reading through a few of them u will start to get the idea of what mods to start doing to your car.
good luck and welcome to the site.
https://www.sau.com.au/forums/topic/250199-r33-gtst/#findComment-4336361
    • That's it. Too rich for me. I'm out. If it does start to sell in pieces, I'll probably register an interest in the diff & axles, gearbox & tailshaft, and maybe the brakes.
    • I tried my best, well I see how it is though... It's time to be ruthless! I'll up my bid with a JVC sub and an amp to run it, 8 stainless steel drink coasters with a rubber backing, and a photo of Tom Cruise. Oh, I can increase the cash portion by 20 cents if that helps.
    • Or if it's grey, is it watery? Does it do it after you've been for like an hour long drive it will still do it, or just near the start of the trip? As GTS said, does it seem like oil (blue), water (white/grey) or fuel (black)? Sometimes the colour can be hard to see clearly too for what it is, as GTS says, what's it smell like?
    • I wonder if part of it has to do with when you've each bought the kits. I honestly have the feeling that the silicon joiners in the 2000s were actually better quality than most of what you can find these days. Even in the same brands. Everyone racing to the cheapest price while still trying to make profit means lower quality parts. For coolant, I personally would be going with rubber, OR, converting the radiator and engine to use the huge AN fittings hose for radiators.
    • If shift solenoid A is bad, that explains limp mode --- now you're in the same position as I mentioned previously, in that the next step is to confirm loom/wiring integrity from TCU to gearbox connector with a multimeter (the TCU cannot detect a broken wire, which can happen ..ie; rodent damage, loom rubbed through)...and then finally measure resistance (at the gearbox connector) for shift solenoid A ... ...once you confirm shift solenoid A is bad (open circuit, really low or greater than 40ohm resistance), then it's a job ; you have buy a complete solenoid set, get under the car and drop transmission oil pan, and remove valvebody assembly (the solenoids sit on top), replace solenoid set, and reassemble....it's not exactly a fun task, but readily doable.
