Hello all.
I've have a question about RB31DET's.
What makes them 31's, different from the 30's?
I have a series 2 N/A RB30 that I'm bolting a RB26 head to & putting it in my Z32. I'm going to be using forged pistons antway & was wondering if the RB31 is just a overbored RB30. I've been searching around on here & the interweb but can't find the info on what makes a RB31 a RB31.
Any replys would be graetfully received.
Thanks
Stu.
https://www.sau.com.au/forums/topic/250210-rb31det/
Thanks for the info guys.
87mm bore with stock stroke is only 3032cc, your far better to keep the bore as thick as possible and if you want a RB31 or bigger go with a stroker crank with custom pistons and rods etc.
Not worth the trouble/expense unless your after something different and even more torque than a 30.
A well built 30 is usually plenty in any case.
Rob
https://www.sau.com.au/forums/topic/250210-rb31det/#findComment-4340351
Hi Rob
Since no one has asked the question I will.
What does one of your RB33 stroker kits cost ? and what does it consist of ?
I am just curious as are a few on these forums.
Cheers
Rob
Edited by Spoolup
https://www.sau.com.au/forums/topic/250210-rb31det/#findComment-4340880
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
