post-58479-1230356683_thumb.jpgpost-58479-1230356683_thumb.jpgFor sale is an R32 GTR 1990 model.
Specs are as follows:
Engine has been rebuilt about 1500km ago using excellent quality components.
Forged pistons 20 over
Argo rods
ACL race bearings
Nitrated crank
block was chemically cleaned and crack tested
new welsh plugs
bored and honed
cylinder head was cleaned up, surface ground, pressure tested, 24 valve seat adjustment.
cams are standard
all gaskets are new.
Have all reciepts to prove!!!!
Turbos are N1 spec garrett items
Twin 2.5in exhaust to the cat then 3in right through
Everything in the engine bay is polished, looks great.
final comp 9.1:1
Vehicle has been dyno'd at 235kw on 18psi with a final tune still to be had.
Injectors are nismo 660cc items
Fuel pump is in tank walbro 255lpm 500hp
ECU is Apexi
Interior is in very cood condition. No holes in seats etc.
Wheels are 17 in tyres are about 80% all round.
Suspension is all standard GTR.
Price is $16000
Rego till oct 2009
If you need more info call on 0414 444 522
https://www.sau.com.au/forums/topic/250256-r32-gtr-gunmetal-grey/
so oil restrictors in the head? any oil return mods?
what brand pistons?
metal headgasket?
hows the body/paint?
any interior pics?
apexi comp asin power fc with handset?
wat boost controller?
Edited by shy_s6
Pretty sure the oil system is still standard and standard return system, i'll have to check with dominator. I think the only alteration was a slightly higher return valve spring.
Supertech forged pistons and argo rods
Head gasket is race series composite all supplied by dominator
Body is in good condition, slight ding in passengers rear quarter at the lower half near the sill panel.
Paintwork is still good.
The apexi power fc has hand controller
Boost controller is just a duel stage turbosmart item
Will post up interior pics.
Cheers
Hi,Have you done any mod to the oil pump shroud? GTR32 has this weak point.Coming up to Sydney Next Monday to Thursday, would like to inspect the car.I have got 3 GRT34( 99 V-spec, 02 V-spec II. 02 V-specII NUR, and 6 GTR33 ) would like to line up a GTR32 and working on importing A GTR35 )
Would you be interested in swapping? 2000 S2 Stagea, 99 RX7 S8 , 94 Supra or even some Hiace turbo 2WD and 4WD
Alex and Tim Melb. 0439818008
:) :) :(:banana:
wat a champ start a thread and post up these bad boys
Wow!!
You a car dealership?
All the oil pump system is standard as far as i know. Pretty sure the only alteration was a slightly higher rate return valve spring.
Don't really want to swap, just need to sell the car, but thanks anyway.
You can contact me on 0414 444 522 to arrange a time.
Cheers
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
