Mmm, I think black eyed man is envious. Maybe he would be happier with the creaky, squealy, squeaking VP if he got rid of his creaky, squealy, squeaking kids, lol.
was getting out of mine at the shops the other day, just parked and left motor idling while closing windows and sunroof's and some 40 odd year old lady walked past the front (had reversed into carpark) and gave me the dirtiest look possible, ie as if i'd gotten out and taken a s**t in the middle of the carpark or something. then got to her car bout 3 spots down, by which time i was out and just with a slightly raised voice said. just cause u can't afford it, she looked up and i turned and walked. found it quite amusing though was half expecting an abusive note or smashed window when i came back.
  • 3 weeks later...
saw a dodgy as , r34 front conversion on chinook street everton hills. hard to describe but everything was off.. looked terrible.
But mind you i cant talk.. i just bought a 300zx.... tears to come whistling.gif
Engine out?
Hahaha, I get this every day... Most of the time it's from 60+ year olds in standard M35s, and I drive past them laying frame and throwing sparks... The digust I get thrown my way is awesome
Dont worry, we all understand. :P
What happens when the chassis is ground away or you catch a the crossmember on a lip?
Subframe sits below chassis.... My sway bar is flat on the bottom and subframe is shiney silver.. Aint scared :domokun:
The person behind you might be when you catch the subframe and come to a stop instantly. lol
So the other night in Pt. Pirie I thought I'd get some fuel and a icecream, on my return from paying I find a rather drunk local standing (swaying actually) in front of my a car with a big smile on his face and chuckling to himself. "All good?" i say to him and he goes "F!@# Yeah, thats cool car hey bro" then proceeds to walk away while still focused on my car. Well you can guess what happened next, yep, BAM!!! straight into the petrol pump in the next row, falls on his arse, then tries to get up by pulling on the hose that is now on the ground!
Was the funniest thing I seen while I was there
Motorbike rider at the lights today pulls up next to me and asks "How hard was it to put the Pioneer deck in? I've got a Blue M35!" Ahaha before he said he had a blue M35 I was like "wtf does this guy want".
Seems a lot of bike dudes are into Stageas!
Getting back to Volvos....
We now have two in the family... Well a silver/grey M35 does count as a XC70 really...
Finally after 160k the wifes Saab 9-5 is now gone, and replaced with this... Still a 2.5 and a turbo...:thumbsup:
Kids are loving the DVD in the back and the space... But number 1 daughter still wants to go in "daddy's fast car".. Have to keep my little girl happy..:rofl2:
Haha, glad that XC70 isn't silver Nick, could get confusing.
Bit iffy with an WRCxxx number plate.
Made me smile as well... Especially as they had a couple of Evo's on the lot as well... Had been taken in Trade against a S60 T6 AWD in seperate transactions..
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
