That's A Nice Looking Volvo Mate.......
By DraftySquash · Posted
Another weekend and another project I have questions about.... I bought a fuel tank sender O ring to install on the car because I'm quite sus on what I've got now. 1. No "whooosh" sound when opening fuel cap 2. If I fill up full tank, there will be a small leak under the car and it comes from the top of the fuel tank, dripping along the side. Stops after a short while 3. Hot days = 50/50 chance to get high as a kite inside the cabin if the car was in the sun for too long This is what I bought: https://www.amayama.com/en/part/nissan/1734279900 My plan was to just replace the O ring but I've got some questions: 1. Does the whole fuel pump assembly need to come out for me to replace the O ring? Or, could I unplug all the connectors and fuel lines at the top, take off the twisty part (17343) and put in the O ring from the top? 2. Is it a very common thing for everyone to just change the pump whenever doing this? I see the Walbro 255 gets thrown in a lot but I've got no issues with my pump so far. When I did the tune, I asked the guy to check my fuel pressure and he said there were no issues too. But is it just a good idea to change to the 255 anyway as the old unit may have been in there for so long? The 255 seems to be a direct fit for GTT (I got no soldering iron) -
By robbo_rb180 · Posted
Normal speedtek issues, bin it and go cdoo# or 8hp. So many issues with these gearsets, a mate went through 3 rebuilds and multiple parts with heat, bearing and vibration issues. -
I wouldn't go near them, they are rubber seals for a reason. Just chuck new cam cover seals, half moons and the spacers for the screws every decade or two. I add a really thin layer of silicone too and it seems to hold together OK
AFAIK on most Toyotas that half moon is usually an aluminum piece that you seal with RTV so you just source the valve cover gasket but I kind of doubt that you'll ever save money buying an aftermarket piece in this scenario. -
By TurboTapin · Posted
If I tossed my money in a fire and filled my transmission with sand, it would end with the same result as buying from Speedtek. Actually, that's not true... My way, I wouldn't have to deal with Speedtek's dick head of a CEO for years on end and all his lies.
