  • Replies 65
Not personally but I want to do the mod at some stage, they're the only place that looks to have the best product for the job. Heres another photo of the topstage guard kit:
I think they look best wth the crease maintained along the body but a few people have moulded them flush.
Link to another thread: http://www.skylinesaustralia.com/forums/Wi...ge#entry3259489
Edited by MintR33
do you know the $$$$$ of them
  • 3 months later...
update....
guards done at Detroit Custom Bodyworks 9567-6511
the pictures speak for them self from start to end.
rims are 18 by 10
tyre 255 35 front and back.
Edited by WARLORD
Hey mate, the progressive pictures look good...can't wait to see the finished product...I am after the exact same thing on my R33 GTST... can you please tell me the costs associated with these flares and what type of flare 'add-on' have you chosen for your R33. You can PM me if you prefer to keep this confidential.
Thanks mate...the car is looking hot!!
hi thanks for your comments,the flares are made from the gtst guards no add on here just great panel work from Detroit which is second to none.As for the cost you will have to contact Adam from Detroit and ask him cos the car is part of a co sponsorship with HDI who also have some of the highest quality parts available in Australia.
The car will be finished soon and the result will speak for it self.
Ill try and keep up the pics for all to see.
by the way the offset is +22
look good man, how many mm did they pump it out? i need this done on my car as well!
got defected this morning for wheels sticking out of the guard lol
olny option left without going wide fenders as they will need gtr rear bar & skirts.
it was about 30mm to 35mm in the front and 20mm to 25mm on the back.give them a call to be exact,you will not find a better job anywhere if you want you should go ask them tomorrow and have a look at the job be for it gets painted.
are the 33's factory painted with 2pak or acrylic?
there would not be a factory car anywhere this side of 1950s russia that is painted in acrylic. unless it's being painted in someones backyard.
oh awesome, i spoke to them today, he said i would have to go in and then get a quote.
ill pop by tomorrow if im free.
hope to see your car there.
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
