there would not be a factory car anywhere this side of 1950s russia that is painted in acrylic. unless it's being painted in someones backyard.
u might be surprised that my dads torana (76 model) was acrylic & my other car (rover) 82 model is also acrylic, unless i misunderstood your response :/
  • 4 weeks later...
  • Replies 65
Indicative price on how much this work would cost from Detroit?
edit: Nice work on the front guards. The finish is fantastic, but it doesn't look like they pumped up the rear enough. The outer rim of the wheel is still a good 1cm past the guard.
in real life it looks much better as for the rear i love it
as for price you would have to call them cos i have no idea as it was part of my sponsorship.
Okay, no probs...
How long did the process from drop off to pickup?
Okay, no probs...
because there was no rush to do it and they have tones of cars waiting for there godly touch it was about 2 and half weeks
Not too bad at all... I might be employing their services in the near future :)
Issue 107 champ, (PMR33)? neat car. how much for rims? i want them in black
Cam
thats someone eles my car comes out in 4-5 months in hpi
the rims are about $3500
http://www.hookupshop.com/Blitz%20rims.htm
Edited by WARLORD
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
