Hi all, the below table are the SPEC for the RB25DE, I have an auto NA 34 and would like to get some idea of the best, economical ways of getting about 150km at the wheels, open to suggestion and if possible please list the mod, cost and the installation cost. :thumbsup:
EngineModelRB25DETypeWater cooling DOHCDisplacement, cc2498TurboNoCylindersSerial 6, 24 ValveMax Horsepower, hp / rpm200 / 6000Max Torque, Nm / rpm255.0 / 4000Fuel SystemEGI (Electronic Gasoline Injection)Fuel TypeGasolineCompression Ratio10.0Bore * Stroke, mm86 x 71.7Fuel Consumption, l/100km9.4
https://www.sau.com.au/forums/topic/250316-na-tune/
If it has to be kept N/A do the following
RB30 bottom end
Cams/Headwork
Decked block to bring compression to 10.5:1 (or through piston selection)
Aftermarket ECU
2.5" Exhaust with highflow cat converters
Install and fabrication costs will vary from shop to shop, but $8K should see a very reliable and well built setup that loves to rev
https://www.sau.com.au/forums/topic/250316-na-tune/#findComment-4337531
150rwkw/200rwhp out of an RB25DE is going to cost you.
Machine work (porting will have to be done and getting the compression up, 10.5:1 probably won't cut it, you should be trying for 11:1 - 11.5:1 for 2.5lt and costs for big cams also)
About - $4000
Aftermarket ECU - Min $1000 then to wire in and tune another $1000
Decent Extractors - $1000
Labour - min $1000
Cams and springs - $1500
Oil an water pumps - $500
Exhaust piping - $750
Lightened Flywheel and new clutch - $1000
So about 11G should net a figure around 150rwkw probably 160 - 170rwkw, but in saying that people would say you spent all that money and get such a tiny power figure, but really that setup would be good for a mid - high 12 to low 13 sec quarter pass which isn't slow for an N/a
https://www.sau.com.au/forums/topic/250316-na-tune/#findComment-4338468
12 second quarters would be asking way, way too much from 160rwkw on a 34. My mate has a Del Sol CRX (non turbo worked to the shit) with 171rwkw and he cuts 12.1 sec quarters, and his car is light as shit compared to the weight of a 34.
https://www.sau.com.au/forums/topic/250316-na-tune/#findComment-4339214
About - $4000
Labour - min $1000
Wow that is a shit load, you might aswell sell and get a GTT, and even with money remaining, do some supporting mods and hit some good figures i guess!
MRXTCZ
https://www.sau.com.au/forums/topic/250316-na-tune/#findComment-4340228
no they are not the same. RB25DE = high compression RB25DET = low compression. The low compression is made up for by boost via the turbo.
http://www.skylinesaustralia.com/forums/Rb...l&p=4306941
Simply bolting on a turbo to the RB25DE will not run properly and kill it very quickly. An RB25DE+t can be done though with the right parts, the right engine management that can handle fuel and ignition timing, and good tuning, and of course supporting mods such as fuel pump and injectors to meet the new demands, and of course keeping the boost level at a safe limit.
The hardest part is going to be whether you can do the labour, or paying a workshop to do it, and of course finding a workshop who will not only do the labour but will be willing to tune it. A fair few workshops refused to do it, or refused to tune such a set up. If you do it, make sure the tuner is confident with it.
I think it will be wise for you to have a read through the How To Turbo N/A Skyline thread. What I said above is a very very condensed version. It will also be good to look at the differences between an RB25DE and RB25DET engine.
http://www.skylinesaustralia.com/forums/tu...N-A-t33407.html
In regards to an LS1, this has been done on a number of S13's and a quick google shows that there's R34's that have had the LS1 treatment. There was a 320kw LS1 powered S13 in HPI Magazine issue 83.
Could always do a twin turbo LS1 :(
http://www.ls1.com.au/forum/showthread.php?t=61035
http://videos.streetfire.net/video/Nissan-...1-V8_169208.htm
http://videos.streetfire.net/video/Nissan-...-with_95344.htm
https://www.sau.com.au/forums/topic/250316-na-tune/#findComment-4341022
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
