well my car is off to see u know who. i just want to know what i should get away with in regards to what i can leave on my car. S2 Stagea by the way
fitted ATM
front mount utilizing standard return pipe sitting neatly behind bumper but unfortunatly only one mount could be used so it moves ever so slightly.
xenon globes (they are the standard item)
3 inch from the turbo back (no cat at the moment but will fit asap) pretty quite and will be quiter once cat fitted
R33 front discs and callipers ( had to bend the dust covers back to fit the bigger discs and had to use braided lines ) back brakes still standard. still have standard fronts at home
fully adjustable coilovers. still have standards at home
upgraded sway bars
shift kit (auto trans)
pod filter and hard intake pipe are removed already to allow for plum back BOV to be returned
now my biggest problem is my turbo. seeing as it now has a garret core in it i had to use braided lines. it still has the original nissan comp cover on it but the exhaust side looks slightly different than a standard one.
cheers for any advice
https://www.sau.com.au/forums/topic/250349-how-stock-to-go/
fitted ATM
upgraded sway bars
Front mount u might get away with
Xenon globes may be an issue
Exhaust - its gotta be below 90db so get tested beforehand just in case
Coils will have to go. not allowed to be adjustable at all
Swaybars will be fine
Turbo may be an issue
thats just my guess at reading this so far and hearing whats been going on lately
https://www.sau.com.au/forums/topic/250349-how-stock-to-go/#findComment-4337786
no cat is a big fine if they find you dont have 1. but your not a mechanic and shouldnt be expected to know if it has 1 or not would be my defence if they wanted to play that game.
whats ok and not depends on weather and if its that time of the month
coilovers wont pass 1 of their fav things to look for.
Edited by Inline 6
https://www.sau.com.au/forums/topic/250349-how-stock-to-go/#findComment-4337788
Turbo will have to go, possibly the braided lines also, no sure if they are too keen on them. Also the suspension and the xenon lights... Calipers SHOULD be fine however unless the braided lines are ADR approved they too will have to go. Don't see a problem with the exhaust so long as it's not too loud or the FMIC either so long as no reo bar has been cut in order to fit it.
https://www.sau.com.au/forums/topic/250349-how-stock-to-go/#findComment-4337815
i still have the stock turbo and all the lines but i really dont want to change it all over cause i know i will never change it back which means somebody on here will be able to pick up a bargain. i will just change everything else back to complience state other than the exhaust and fmic and see how i go. if i have to do the turbo i will but i will try and get it through first. im glad it hasnt been in to get the nistune board yet or they would find that to.
https://www.sau.com.au/forums/topic/250349-how-stock-to-go/#findComment-4337870
Lucky there Craig, they usually will pick you for it as they are illegal. I know when my 33GTR went though I had to remove mine. Apparently it all has to do with the fact that there is no washer jet for the light assembly. Load of shit I know but thems the rules :banana:
https://www.sau.com.au/forums/topic/250349-how-stock-to-go/#findComment-4337908
Turbo MUST be standard. Why don't people understand this?!?! They CHECK the housing numbers, etc on the turbo. Chuck on the STOCK turbo unless you want to go through Regency again. They affect emissions. You cannot get away with putting in a different turbo in Regency. You can grind off the housing numbers, put a beanie on the turbo, etc but it won't get past the inspection!!!!
I told this to the dude who owned the 32 GTR who got done, he ended up leaving his N1's in and they found it. Had to go through again.
Make sure your turbo is the stock model.
Steel wheel is fine, high flow should be fine as they can't check inside the turbo.
Preiss, most 34's, if not all, came out stock with Xenons hence why you passed.
https://www.sau.com.au/forums/topic/250349-how-stock-to-go/#findComment-4337969
is going through a second time really that bad? they usually make you go twice anyway to make that extra buck. they always find something stupid over looked like a small grease stain or something like that
Uh... well.... you do have to pay another inspection fee, drive around longer with a defect notice on your car, etc etc etc
That's like saying "I wont take off my atmo BOV because I know I'll go again... so whats the point?!"
It's plain stupid.
https://www.sau.com.au/forums/topic/250349-how-stock-to-go/#findComment-4338047
well i don't care if i don't pass the first time! i've learnt my lesson already i wasted alot of money to pass the first inspection but then i had to come back anyway for something stupid, the front indicators have to be 350mm from the ground and mine were 345mm. next time i'm just gonna go in as is and let them give me the list of what needs to be changed or fixed. helps with the money wasting bit of changing something that didn't need to be
https://www.sau.com.au/forums/topic/250349-how-stock-to-go/#findComment-4338058
im saying they usually find something stupid to bring ya back for a 2nd trip anyway and you end up fixing stuff that dont need fixing etc which can be a pain in the ass running around with permits if you dont have registration.
while it is ideal to get through the 1st time its often not the case cause they find something stupid like o theres a lil crack here on this plastic, and going nutz making every single stupid thing stock again that didnt need to be can be painful when its not needed.
also if you correct what the original defect was for youll get yaself like 48 hrs to drive it from the the time you go in so you do get to enjoy it for a bit anyway. i did 500k's in that time :blush:
you go in get a list of shit to do and thats all you gota do for the 2nd trip they hardly look at the car. and you'd be surprised some of the thing they dont check the 1st time such as seat belts wtf 1 of the most important safty parts on the car
Edited by Inline 6
https://www.sau.com.au/forums/topic/250349-how-stock-to-go/#findComment-4338063
See personally I don't mind having to go back because they found something. I went to my first ever inspection a week and a bit ago and they went over every little part of the car in detail, It costs $135 to get it looked at first time and $67 i think he said if you gotta come back.
For one, a quality workshop would charge around $150+ anyways for a complete check over without fixing anything and secondly at regency you get told the facts about legality of modifications, you can ask them questions of what is and isn't illegal.
I think the prices are fair and they might find something important that you might not have spotted or overlooked like they did on my car.
Of course, this doesn't justify them being anal about engine/suspension mods but you should have been prepared for a defect when you decided you were gonna put them on.
https://www.sau.com.au/forums/topic/250349-how-stock-to-go/#findComment-4338231
ok so i spoke to a guy who works at regency, he is the step dad of one of my mates.
my brakes will be fine as long i get a request to upgrade form filled out and have some braided lines made up that have ADR approved stamps on them.
as the turbo looks stock from the outside it should be ok. it still has all the original heat shields fitted and has a nissan comp cover on it.
everything else but the zorst and frount mount has to go.
cheers guys
https://www.sau.com.au/forums/topic/250349-how-stock-to-go/#findComment-4338350
if you ring regency they will tell you a fmic is ok . i know this becouse my son got done for fmic and pod filter i rany regency and was told niether of those items are a defectable item so we went to the eliz police station they rang regency and removed the defect.
still charged us 30 bucks tho lol.
https://www.sau.com.au/forums/topic/250349-how-stock-to-go/#findComment-4338764
so if you get ur lines modded to fit stock turbo visa versa it would be sweet? thinking of having a stock turbo hiflowed as my defect turbo LOLand that way i can leave the braided lines there
https://www.sau.com.au/forums/topic/250349-how-stock-to-go/#findComment-4339244
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
