  • Replies 41
ok this morning, i flushed out the coolant, put some coolant flush through it to try and unclog any blockages, then filled it up bled it by having the cap off and heater in full ball and now we wait and see if it is all good..will keep posted
Overheating is also caused by a worn clutch fan. These can be refilled with silicon oil for around $10 or bought new for $300....i prefered the $10 option.
Brand new price is >$300 :)
And $10 for new oil? I had no idea you could just replace that...clutch fan is easy to test anyway...once the engine is warmed up it shouldn't free spin anymore, it should be locking a little at idle...
howd u go?
as above, about halfway on the gauge is around 80 degrees or so.
In regards to the horn
on my old VL I had a similar problem where it would go off randomly, one time i was driving down my driveway just about to pull onto the road and it just went off and wouldnt stop. This happened just as a cop car was driving past lol lucky they didnt seem to care. Anyways, it was an aftermarket steering wheel and if i tightened it up to tight that would cause it to go off when i indicated or turned or something like that, it was also blowing a fuse which would make the relay for the horn click on and have it go off. It was due to a bad earth or something so just check the wiring, if youve got a standard steering wheel that uve never touched then it probably wont be that but just an idea for you
howd u go?
yeah all went well thanks dude, prob go to the radiator specialists tomorrow to try and get a pressure test done to see exactly what was happening.
Nah the horn is stock standard, prob is it has an airbag so i cant just remove it, but i kno what u saying mine goes off sometimes at the slightest turn roundabouts mainly and sometimes it goes mental and wont stop and i just have to press the horn button on the wheel and it stops really fkn weird, it actually one time went off when the car was parked in the garage and i slammed the bonnet shut it was mental...no one seems to know
ok i went to natrad in seaford today highly recommended by the way and he took the hose off and found the problem right away, the part of the radiator that the top hose connects to has broken off the ridge part that stops it from sliding off when the hose clamp is on....it was broken in the hose and we just fished it out and pretty much now need a new top filler bottle, was quoted $260 hope thats a good price anyway for the time being he put this plastic ridge on it dont know how he did it...like this blue silicon stuff, very dodgy as he said but will get me by til i get it fixed
so we shall see how it goes now
thanks for all the help people always appreciated
well for a update today whilst driving the car overheated again pulled off opened bonnet and what do u know the hose has not blown off this time so I was stumped, however the steam was coming from the other end of the top radiator hose the one that connects to the engine, I felt the clamp and it felt lose so I gt my screwdriver out and I could move the hose clamp around so I tightened it, put water back in and it was fine was at normal temp, the racv dude reckons all it water hoses under the engine need to be replaced as they are still original does that sound right? I was on nepean hwy just past edithvale station is anyone saw me LOL
Old hoses become brittle and do not flex enough to seal. So new hoses might be the go. Natrad should have told you this though? Usually they jump at the chance to sell you more shit.
Replace the hose and the clamp, cheap as chips, be sure to clean the connecting pipe on the engine side. Also, while you have that pipe off you can check the thermostat for jamming.
Good luck and let us know how you go.
i rang the radiator guy and he said he couldnt beleive he forgot to check the other end of the hose...he reckons they dont build up pressure if its actually lose...how on earth am i gona replace all the hoses under the engine lol that will cost a fortune as i would prob have to order from nissan who are not cheap.....i will replace the engine hose and clamp at the very least
silly question where is the thermostat exactly located so i can check it?
arghh the bottom radiator hose is such a bitch to undo lol i did it to drain the radiator as i couldnt locate the valve to open it and then when i had to put it back on pwahhh the chassis got in the way big time...will check ebay now thanks dude
Id say with the horn thing if ur pressing the horn button on your steering wheel and thats making it go away then its probably a problem up around the steering wheel area as i said before. Dunno how u go about pulling the steering wheel off to check it seen as it has an air bag
maybe pull the colum surround off and try to look up and see if u can see any thing loose or broken
Thats my guess anyway....
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
