selling my 'chopped' mspec fornt bar, was chopped to fit my fornt mount but now i want an aftermarket front bar so im going to sell this
there is no damage to the bar its in tip top strength shape
also the s-type grill is for sale too (my new front bar has a built in grill) and thats also in perfect condition with brand new silver mesh :)
pic is attached
asking $300 for the front bar
asking $150 for the grill
asking $420 the lot
https://www.sau.com.au/forums/topic/25041-mspec-front-bar-r33/
^ Bump ^
Off topic but...
DJ_L3ThAL, can I ask what size/brand IC that is and where exactly did you have to do the chopping?
I'm gunna have to do some chopping on my M-Spec bar soon as well, and also make room for the fog lights, any tips?
Edit: Mine
i didnt do the chopping, the guys who fitted the cooloer did, but please, PM me about non-selling my fornt bar related things eh :P
cheers
and cmon, i know someone must need a bar, especially someone who is getting a front mount and needs space, this will save u form having to chop your current bar!@
bumpetty-bump
im getting my new fornt bar most likely next week so i'd like to sell this around the time i get the new one, im getting to the point where the car can hardly even fit in the garage anymore! LOL
  • 6 months later...
Phuck..... Nath hows it going mate.
Tried emailing you about your grille, did you get it. I've been trying to scam this off you for ages........ I thought you sold all this $hit ages ago. Well, if you've got it, can i grab it off you.
Cheers!
Guest
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
