need the plastic bit (fascia) that goes around the AC/stereo in R34 GT-T centre console and also the 2 metal brackets that hold the AC/stereo inside the centre console.
Located in Sydney.
If anyone knows a wrecker in Sydney who has an R34 GTT (coupe) in stock pleeeeeeease let me know i've rung around all day
im guessing your goin from tv to gauges?
just to let you know that r34 gtt and gtr brackets/ac unit and fascia are the same. got mine off a gtr...
just a heads up
Edited by R-SPEC
thanks for the heads up mate. Is the GTR stereo fascia the same (ie. the double din surround that goes around the stereo) ?
yeah I'm going from TV to nothing (on the top of the dash) .. I'll just get those justjap guages and stick them in a single din unit under the AC late.
turns out the friggin AC surround does not fit (too narrow) once you move it up just under the vents where the TV headunit used to be ... so now I need the AC surround and stereo fascia (double din) from a normal (non-TV) GTT/GTR
Btw, R-SPEC, did you have to change the brackets in your GTT once you got rid of the TV and associated headunit ?
Edited by Delta Force
