hey guys, on a cold start i get a grinding noise for 1-2 seconds max after the car first turns over.
engine is 25det
it tends not to happen when the car is warm.
2 area's i was thinking are starter motor (although why would this be diferent when warm) and oil viscosity
i use motul turbolight 10/40 as do MILLIONS of other on here...
any ideas?
https://www.sau.com.au/forums/topic/250435-ugly-ass-noise-on-cold-startup/
Could be a worn bearing, start it cold with a mate in front or vice versa so you can try and pin point it. Lots of ancillary devices can have bearing issues (air con, power steer pump, alternator)
If you can be more specific that would help.
It will change with temp because friction coefficients are effected by temperature. Hold/Cold causes things to expand and contract etc.
Edited by ActionDan
yeah power steering pump is on the way out... you can hear it grind a tiny bit with a stethoscope on idle.
exhaust is bot touching anything.... i've been over that with a fine tooth comb as a previous (read NON japanese) exhaust did that and caused me all sorts of headf**ks.
see this was my idea... DGAF if its just the starter motor gettin noisy... i'd rather pay for go fast mods...
it never happened till i got remote start...
remote start (viper alarm) keeps cranking for a predesignated time, and with the pfc the time the car takes to start could be anything :D
so to use remote start (which i never do now) it grinds the shit out of it for like half a second most times
There are a few threads on this one, yes it sounds like the starter gear is not returning quickly as it should.
Odds are if you remove it it will have 10+yrs of clutch dust, road grime and oil on it that is slowing/stopping it from returning correctly.
Remove-clean-replace. Unless it's chewed the starter gear or flywheel badly you should be ok.
starter motors have a overrun clutch, If your remote start has been over cranking, the sprag clutch maybe worn/damaged, when you start normally the engine over speeds the starter motor, you release key, usually the sprag clutch slips and the gear can retract. cos your clutch is damaged it maybe holding the gear on a little more
  • 5 months later...
sorry to bring up an oldish thread...but mine has started to do the exact same thing only few days ago....and only does it durin cold starts for 1 or 2 seconds after the engine has started
the noise is comin from the starter motor area so im guessin the starter gear is doin sumfin wrong
how can this be fixed? would the starter have to pulled out?
its totally the starter moter... just cant release quick enough... problem is same same now.... no worse... i'm not gonna bother about it. everything else in the car works fine :P
+1 on starter motor.
mines doin it too.
Dam 33 starters.
Mine did it a while ago, about 2 yrs to be precise.
Took it out, greased it up, was dry as a bone.
hooked it up to 12v battery, let it spin a couple of times till the noise went. Sweet as.
But its startin to do it again, might just replace it this time round.
RJ
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
