hi'yas
since start of December had my car in the shop doing a big head upgrade job, port etc with poncams, etc
the head was fitted and everything setup but was hell smokey while running
a pull down of the head reveals oil on top of piston no.6, other 5 are dry and fine
what can cause a failure in around the back area of the head?
oil pressure has been restricted at the head with x2 tomie oil gallery restrictors, then again at the turbo becuase pressure was too high there.
the turbo oil restrictor is now set and works well for the correct flow (journal bearing turbo)
however head has the issue with piston no.6 oil on surface area, ie leak from head in that specific area. was "wet" on top when others were dry
used 6mm new valve seals, new valve seats and guides but stock valves.
head was ported etc, by a rebuilder outsourced by the garage, with a Cometic head gasket (1.2mm x 87mm) & arp head stud kit, along with 8.8mm lift kit and poncams (tomei) with oil restrictors
Please - any thoughts on what may have failed?
Ive said to the tuner that it must be a head installation problem, car was fine beforehand; want to send the head back to the rebuilder to be redone properly - or at least redone over piston no.6 area.
whats the go here?? thoughts ??
https://www.sau.com.au/forums/topic/250457-rb25-head-leak/
Hmmm i've been thinking about this and the only thing i can think of is oil leaking through the head past the valve stem seal into the intake and then past the valves. So to me it looks like a valve stem seal not installed correctly?
Im sure some one on here a bit more experienced in head building could answer this question.
https://www.sau.com.au/forums/topic/250457-rb25-head-leak/#findComment-4342301
valve stem seals were seen to be all within tolerance. although Im pretty sure Neo stem seals were sent to me in my parts order.
the valve guides have been replaced and the original install work re-gone over, builder couldnt find a fault as all was within 'normal' scope.
being re-installed now, tuned tomorrow so we'll see how the story ends.
https://www.sau.com.au/forums/topic/250457-rb25-head-leak/#findComment-4348677
reinstalled and taken back off again
leaking oil still on top of piston #6
fk me
what could be wrong with it? told em to replace the seat, seal and guide, its been pressure tested and passed - perhaps a cracked head?
if a cracked head, how can that fkn happen, when the car was fine before the tune - no oil usage, no smoke etc.
how do heads crack? possible that the machinist dropped it??
any advice plz
https://www.sau.com.au/forums/topic/250457-rb25-head-leak/#findComment-4353298
sounds more like a head fark
ok doe's the inlet port show any signs of oil in it compared to the other inlet ports ?or do they all look the same .check the inlet yalve stem for straightness or and grooves along the stem that oil could pass thru .
check the valve guide for wear on one side of it or is showing that its wearing evenily.
it could be a crack from under the cams going into number 6 port i was hoping you would have had this sorted out by now bit hard to offer any more advice without seeing the head .
did they check the head for softness b4 starting the work ?
cheers mid life crisis
https://www.sau.com.au/forums/topic/250457-rb25-head-leak/#findComment-4353361
I'll chat to the tuner again (unless you wanna give shaun a call? to offer advice?), but its not in his hands either - outsourced to a machinist.
they should be replacing everything around #6 piston area of the head, and the pressure test came up ok anyway.
hasnt been xrayed because before it went in for some work it was 100% perfect and 200kw easy, no strain.
massive head fK because its out of my hands (here for advice to pass on - ) plus my fund$ are short!
im 200% positive the head was fine before it went in for upgrades. wonder what happened at the machinists? dropped the head and cracked it? faulty stem that hasnt been picked up twice now? (3rd time back at machinists, been bolted on twice and blew oil)
basically now just want the bloke doing the work (not the tuners, good peeps) to fix the fkup with all-new components / handywork around piston 6 area.
https://www.sau.com.au/forums/topic/250457-rb25-head-leak/#findComment-4355477
cracked head.
1
around the guide area the metal has deformed.
second head has been sent with mine to the machinist (who the tuner backs 100%) to swap it all over and redo again
just on of those things apparently.
close thread, unless ppl need advice on what not to do.
ie dont buy valve guides off the internet, let the shop doing the work supply them.
I'll learn from that.
https://www.sau.com.au/forums/topic/250457-rb25-head-leak/#findComment-4355501
So it was the valve guides afterall, thought so.
I should have my head back from them next week, fingers crossed mine turns out fine, the only thing i supplied was the valve springs.
Edited by PM-R33
https://www.sau.com.au/forums/topic/250457-rb25-head-leak/#findComment-4356123
Not wrong type gary, just bad luck?
Im told they were frozen then tapped in, one has made a bulge of sorts when expanded, resulting in a micro crack. as far as Im aware
hasnt been xrayed but swapped and left with the tuner. no charge. was fully pressure tested and ok there, but spat oil. fixable / patchable I reckon.
end result was a new head being decked out for me, but just one of those things.
was a 7.5 week job but nothing but praise for the tuner (Boost Worx)
fantastic on the road. beautiful end result, very punchy, pulls hard, & isnt held up anywhere - on the road
cat converter is holding it back power wise, resulting in boost drop still.
will fix that up next tune midyear and be happy with it for a while :(
http://www.skylinesaustralia.com/forums/Fi...Of-t252849.html
https://www.sau.com.au/forums/topic/250457-rb25-head-leak/#findComment-4372838
    • Welcome back to the scene! Godzilla Motorsports were well regarded back in the day.  My GT-R had work done there prior to my ownership.   SRS (Street Race Solutions) in Toowoomba worth a look.  They've built some pretty wild Skylines. Their YouTube channel is comedic to watch!  I'm sure they're all on the glass BBQ but they get shit done! 🤣
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
