I got a 2nd hand Z32 AFM which has 5 pins on it. Then i got a Z32 plug 2nd hand from another guy and i just realised that it has 6 pins and there is no way it will plug into the Z32....
A: what the hell?????
B: what can i do? Is there a way to pull the pins out of the plug? Can i just cut down the plug so it will fit?
Thank You
https://www.sau.com.au/forums/topic/250511-z32-afm-and-plug/
Thank You
or option c buy the correct plug
I have figured out what happened. the AFM is a Z32, the plug i have is for a Z32. the problem is someone soldered a 5 pin plug onto the AFM. So now im off to the wreckers to see if i can get a Z32 plug for the AFM.
