Item: Complete Rb26 Bottom end including sump if needed. (from R32)
Age: Most parts Brand new, crank used but crack tested.
Condition: All new parts with machining done (Almost at the stage of final assembly)
Price: Complete sell for $6000firm Note: value well over $7000
Willing to separate tho would rather sell together considering the work thats been done.
Value:
Cp pistons are +20 thou, well over $1000 new
Brand new Eagle rods $500+
N1 block is brand new item with machining, $2400 + machining work
Used tested cran $1000
acl bearings & arp main studs $200+
Rb26 sump + diff $500
+ the machining work $$$$
Comments:
Machining done as follows,
Hot tank Crank, Crack test crank,
Studs nuts fitted to main caps, Line hone 7 main's,
Rod check/set hone small end, rod check big end and align.
Tunnels measure sizes measure crush, check & set bearing clearances
Drill tap fit Plug
Comp spec micro polish crankshaft
Bore and Hone 6 cyl Torque plate
Trial build check deck and square
reface block square.
Balance 6 cyl manual.
Reason for sale, going to use my Mahle/Pauter rod combo instead
Edited by Angus Smart
Bump,
Would like to add all the work has been carried out by a very good shop in Adelaide Pm me if your interested to find out who.
good luck with that one buddy...
I've just checked the crank, dew to a few questions. it is the larger sized crank drive.
Cp pistons are 86.5mm (+20thou)
and going on what i can see, the ring gaps are the only thing left to be done +final assembly
Pistons and Rods are sold and there is no arp studs left
the rest is still up for sale
Block/Cradle, crank and bearings. will take 3400 for block and crank,
photos of block etc..
Rods and pistons sold to me! Thanks Andrew!!!!
Andrew is a great guy to deal with guys!
Free bump!
Block. crank cradle bearings still available.
Crank was rebuild/checked by Crankshaft rebuilders in Sa or Victoria.
U willing to sell the cradle seperate if so message me. Cheers
  • 1 year later...
i'm new to the forums so i can't send PMs yet.. do you have an e_mail where i can contact you?
i'm interested in the bearings
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
