Item: Complete Rb26 Bottom end including sump if needed. (from R32)
Age: Most parts Brand new, crank used but crack tested.
Condition: All new parts with machining done (Almost at the stage of final assembly)
Price: Complete sell for $6000firm Note: value well over $7000
Willing to separate tho would rather sell together considering the work thats been done.
Value:
Cp pistons are +20 thou, well over $1000 new
Brand new Eagle rods $500+
N1 block is brand new item with machining, $2400 + machining work
Used tested cran $1000
acl bearings & arp main studs $200+
Rb26 sump + diff $500
+ the machining work $$$$
Comments:
Machining done as follows,
Hot tank Crank, Crack test crank,
Studs nuts fitted to main caps, Line hone 7 main's,
Rod check/set hone small end, rod check big end and align.
Tunnels measure sizes measure crush, check & set bearing clearances
Drill tap fit Plug
Comp spec micro polish crankshaft
Bore and Hone 6 cyl Torque plate
Trial build check deck and square
reface block square.
Balance 6 cyl manual.
Reason for sale, going to use my Mahle/Pauter rod combo instead
Edited by Angus Smart
Bump,
Would like to add all the work has been carried out by a very good shop in Adelaide Pm me if your interested to find out who.
good luck with that one buddy...
I've just checked the crank, dew to a few questions. it is the larger sized crank drive.
Cp pistons are 86.5mm (+20thou)
and going on what i can see, the ring gaps are the only thing left to be done +final assembly
Pistons and Rods are sold and there is no arp studs left
the rest is still up for sale
Block/Cradle, crank and bearings. will take 3400 for block and crank,
photos of block etc..
Rods and pistons sold to me! Thanks Andrew!!!!
Andrew is a great guy to deal with guys!
Free bump!
Block. crank cradle bearings still available.
Crank was rebuild/checked by Crankshaft rebuilders in Sa or Victoria.
U willing to sell the cradle seperate if so message me. Cheers
  • 1 year later...
i'm new to the forums so i can't send PMs yet.. do you have an e_mail where i can contact you?
i'm interested in the bearings
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 馃憤
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
