I have 9 fully rounded off wheel nuts that i cant remove, they are resessed into the mag so either drilling out studs or using a female easy out will work but i dont know where to find one or where to buy one from any help ?
dude, weld on a piece of metal, similar to an allen key, and BAM.......job done.
and buddy, you didn't learn after doing it to at least 5 wheel nuts?....were you aiming for 10?
Edited by loco_r33
Yep, smashing a socket over them is the way to go. I lost my lock nut and was told by Tyrepower that I would need to get a panel beater to smash them off as they were the tricky type. The lock nuts were the 'rounded' type with the key pattern recessed into them.
I decided to buy a pack of deep sockets from Super Cheap for like $12 and matched the sockets against the rounded nuts. I ended up finding a size just a bit bigger than the lock nut, tapped it on with a hammer, and was able to remove it with a ratchet.
Took some time beating each nut out of the socket so the socket could be reused on another nut but it's better than replacing stripped studs from smashing them off or something.
Edited by Hydroxinol
ok, buy a slightly smaller socket, i.e. 1 mm smaller or just go imperial and get the wrong size, line her up with a little bit of grease and bash the s1ut over the nut, then take off as normal...
don't go crazy with the impact wrench, tends to round nuts off, especially yumcha nuts which have high tolerance to sizing.
  • 1 month later...
Same thing happened to me, if ur wheels permit, grind a slit in the nut, grab a cold chisel and a shifter. Stick the cold chisel in the slot but dont grab the shaft of teh chisel (shifter will just open, spanners will snap etc ), grab it fairly close to the tip where its flat. also we used a piece of wood to lever against the back of the chisel to stop it slipping out of the groove. also if its the last nut on the wheel usually if the wheel is off the ground u can get about 1mm movement by wobbling the wheel back and forward, every bit counts.
+1 for the smaller socket, single hex deep impact is the best as it will mangle the nut when you tap it on, giving it a good grip.. normal double hex sockets will crack down the side.... how we always do it in the shop.. much safer than drilling, grinding, etc.
cheers
Linton
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
