Just in the process of weighing up my options as to get a spare factory turbo hi flowed or just go for a good second hand GT-RS.
Its going in a R33 sedan, and would like to get about 250-300kwatw.
Any other options i could look into would also be great, and rough prices on hiflowing
https://www.sau.com.au/forums/topic/250558-turbo-options/
Hey mate,
The two options you have listed are really the best turbos for a decent power increase without chasing too high a figures and without having to change much more about the car ie: keeping it looking standard.
A hi-flow on a standard turbo will get you up to around 240rwkw maximum
A HKS GT-RS Kit will get you closer to 260rwkw.
Now be aware that both of these options need some additional mods.
At the minimum you would be looking at upgraded engine management in either the form of a SAFC or Power FC, new fuel pump and if your going over 240kw it would be a good idea to do injectors to (Power FC required). At these power levels the standard clutch would also be towards its limit.
So in answer to your question :cheers:
I personally would go straight to the HKS GT-RS kit. High flows are not exactly cheap and from experience ive learned its best to aim a bit higher and do it right once, the first time. This kit will give you awesome response and great usable street power. You will be thrilled :)
There are some traders on here selling the GT-RS kit for $2800~
To get a standard turbo high flowed by GCG is approx $1600~
Hope this was some help buddy :)
-Dragonforce
https://www.sau.com.au/forums/topic/250558-turbo-options/#findComment-4340711
Thanks for the help guys :(
Was nearly going to buy a good second hand gt-rs but wasn't sure if it would be overkill. The hi-flow question mainly because i have a cactus std neo turbo in need of a rebuild.
Thanks again for the help, much appreciated :)
https://www.sau.com.au/forums/topic/250558-turbo-options/#findComment-4341060
GCG with cams= 260rwkw, brand new turbo. cops wont know its there
where you mentioned a second hand GTRS... and it says HKS on it.
check out the turbo sticky thread and do a search :( some epic threads on GCG's, GTRS's, and the GT30series.
https://www.sau.com.au/forums/topic/250558-turbo-options/#findComment-4342240
What about a GT2871R?
They do a Skyline version of it now at horsepower in a box
Thats what im considering for my turbo upgrade atm. Pretty sure there garretts answer to the HKS GT-RS which i was originally considering
https://www.sau.com.au/forums/topic/250558-turbo-options/#findComment-4342235
Get a hi-Flow with VG30 rear housing, Im aiming for about 260-270rwkw with my auto after I get the rear housing Fitted and retuned with the Vipec.
A guy in sydney is getting 320rwkw from this same turbo in a manual, but I think he is running a forged motor with a few more intake and fuel mods.
https://www.sau.com.au/forums/topic/250558-turbo-options/#findComment-4342566
Yeah that was going to be my question , the GCG Hi Flow with the VG30 0P6 turbine housing .
Internally they are a fair bit bigger than the RB25 housing so with other top end work they are supposed to go well and not have any extra turbine lag .
I'd like to see better wheels in the high flow but I think it may be a case of the small frame GT BB turbine shafts being too small/short and the larger frame GT turbine shafts being too big in diameter .
A .
https://www.sau.com.au/forums/topic/250558-turbo-options/#findComment-4342607
I am currently running the slide hi-flow max over size with the OP6 VG30 rear. The turbo has been excellent with no problems, but it is now time to grab some more power so i will also going the 3076 with the .82 rear. The best power that the hi-flow could get me was 250rwkw. This is at 17psi but when it was bumped up to around 19-20psi the power would drop of so the tuner left it on 17 stating this was the best power curve he could attain. He said this was probably due to the turbo running out of puff up top.
https://www.sau.com.au/forums/topic/250558-turbo-options/#findComment-4342801
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
