Just in the process of weighing up my options as to get a spare factory turbo hi flowed or just go for a good second hand GT-RS.
Its going in a R33 sedan, and would like to get about 250-300kwatw.
Any other options i could look into would also be great, and rough prices on hiflowing
https://www.sau.com.au/forums/topic/250558-turbo-options/
Hey mate,
The two options you have listed are really the best turbos for a decent power increase without chasing too high a figures and without having to change much more about the car ie: keeping it looking standard.
A hi-flow on a standard turbo will get you up to around 240rwkw maximum
A HKS GT-RS Kit will get you closer to 260rwkw.
Now be aware that both of these options need some additional mods.
At the minimum you would be looking at upgraded engine management in either the form of a SAFC or Power FC, new fuel pump and if your going over 240kw it would be a good idea to do injectors to (Power FC required). At these power levels the standard clutch would also be towards its limit.
So in answer to your question :cheers:
I personally would go straight to the HKS GT-RS kit. High flows are not exactly cheap and from experience ive learned its best to aim a bit higher and do it right once, the first time. This kit will give you awesome response and great usable street power. You will be thrilled :)
There are some traders on here selling the GT-RS kit for $2800~
To get a standard turbo high flowed by GCG is approx $1600~
Hope this was some help buddy :)
-Dragonforce
https://www.sau.com.au/forums/topic/250558-turbo-options/#findComment-4340711
Thanks for the help guys :(
Was nearly going to buy a good second hand gt-rs but wasn't sure if it would be overkill. The hi-flow question mainly because i have a cactus std neo turbo in need of a rebuild.
Thanks again for the help, much appreciated :)
https://www.sau.com.au/forums/topic/250558-turbo-options/#findComment-4341060
GCG with cams= 260rwkw, brand new turbo. cops wont know its there
where you mentioned a second hand GTRS... and it says HKS on it.
check out the turbo sticky thread and do a search :( some epic threads on GCG's, GTRS's, and the GT30series.
https://www.sau.com.au/forums/topic/250558-turbo-options/#findComment-4342240
What about a GT2871R?
They do a Skyline version of it now at horsepower in a box
Thats what im considering for my turbo upgrade atm. Pretty sure there garretts answer to the HKS GT-RS which i was originally considering
https://www.sau.com.au/forums/topic/250558-turbo-options/#findComment-4342235
Get a hi-Flow with VG30 rear housing, Im aiming for about 260-270rwkw with my auto after I get the rear housing Fitted and retuned with the Vipec.
A guy in sydney is getting 320rwkw from this same turbo in a manual, but I think he is running a forged motor with a few more intake and fuel mods.
https://www.sau.com.au/forums/topic/250558-turbo-options/#findComment-4342566
Yeah that was going to be my question , the GCG Hi Flow with the VG30 0P6 turbine housing .
Internally they are a fair bit bigger than the RB25 housing so with other top end work they are supposed to go well and not have any extra turbine lag .
I'd like to see better wheels in the high flow but I think it may be a case of the small frame GT BB turbine shafts being too small/short and the larger frame GT turbine shafts being too big in diameter .
A .
https://www.sau.com.au/forums/topic/250558-turbo-options/#findComment-4342607
I am currently running the slide hi-flow max over size with the OP6 VG30 rear. The turbo has been excellent with no problems, but it is now time to grab some more power so i will also going the 3076 with the .82 rear. The best power that the hi-flow could get me was 250rwkw. This is at 17psi but when it was bumped up to around 19-20psi the power would drop of so the tuner left it on 17 stating this was the best power curve he could attain. He said this was probably due to the turbo running out of puff up top.
https://www.sau.com.au/forums/topic/250558-turbo-options/#findComment-4342801
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
