RGR33 Posted December 30, 2008 Share Posted December 30, 2008 Hi Guys, Another alarm install question... I have installed the boot release solenoid to enable electronic boot release in my car, so that i can wire it up to the alarm and have remote boot! But.. i tested the wire from the alarm that is meant for remote boot (red/white) with the multi meter, and it only seems to hit about 0.6 volts. I wired up the relay and it doesnt seem to be working. I tested the relay with the red/white wire and ground, and it doesnt flick the relay over- no sound at all. This makes me think that the output from the alarm is not powerful enough to flick the relay. Which means no matter what i press on the alarm remote nothing will happen. Is there something i need to do to amplify this power enough to power the relay? Thanks guys- my head is swimming with electrical crap that i dont understand enough to do any more! Im stumped! Ryan Link to comment https://www.sau.com.au/forums/topic/250560-peripheral-outputs-on-alarm-install/ Share on other sites More sharing options...
RGR33 Posted December 31, 2008 Author Share Posted December 31, 2008 Anyone? anyone at all? Sorry to bug need to get this done! Thanks guys Ryan Link to comment https://www.sau.com.au/forums/topic/250560-peripheral-outputs-on-alarm-install/#findComment-4341981 Share on other sites More sharing options...
Gambit Posted January 1, 2009 Share Posted January 1, 2009 (edited) The alarm output wire provides an earth for your relay not a 12v. Edited January 1, 2009 by Gambit Link to comment https://www.sau.com.au/forums/topic/250560-peripheral-outputs-on-alarm-install/#findComment-4343379 Share on other sites More sharing options...
Trav33 Posted January 4, 2009 Share Posted January 4, 2009 Did you get this sorted? Not sure how much current the solenoid draws, and how much the alarm can sink, but it might be as simple as: +12V fused --------> Solenoid + side, and then Solenoid - side ------> Alarm negative trigger. Link to comment https://www.sau.com.au/forums/topic/250560-peripheral-outputs-on-alarm-install/#findComment-4346778 Share on other sites More sharing options...
