R32 Gts4 With Rb26
I though it was about time i put something up here about my car.
It started out as a standard GTS4 with only a cat back zorst imported a few month before i brought it in early 2005. first mods were front mount and a set of chrome 18's
I drove around with the car like this for a year or so with no other major mods just a dump pipe, front pipe and a bleed valve pushing out about 160rwkw.
In early 2007 i noticed that my car started to idle lumpy, did a comp test on the motor and found that i had nothing in piston 6. So i decided to go all out and chuck in a Rb26. this is the piston from the rb20
I managed to find a R33 rb26 with 80,000k's with gearbox from Japanese motorsport, i also got some coilovers, strut braces, stainless front pipes and 32 gtr brakes. I also got a Power-FC D-Jectro all installed by Tilbrook Auto & Dyno, the car was tuned by Martin Donnon and made 230rwkw.
Not long after that i got my new plates and earlyer this year i brought a set of 18x8 1/2" Drift teks.
I have now upgraded to R34 GTR rims painted the same gold as the Drift teks and i also brought a GTR interior.
I have now also fitted a GTR bonnet and grill. My next major mods are a set of Garett GT2860-5's, HKS dumps, Nismo pump and Sard 700cc injectors which i hope to have installed in the next week or 2, when there on and tuned i'll post of the dyno sheet, it should be around the 300rwkw mark :cheers:
Edited by DSTROY
  • Replies 46
Amazing work!! love the engine colour, did you choose that or did it come with it?
I painted it myself before it went in, its just spay can stuff with a clear coat, colour is Cyan Metalic you can get if from Super Cheap.
Damn this thing is awesome, a Sleeper and a half!
You couldn't even tell, unless you can recognise the exhaust note and you probley freak the crap out off ppl trying to drag you off at the light.
BTW you said you have an APexi Power-FC D-Jectro installed, but I see you still got the air flow metres in one of the pics... I thought you did not need air flow metres with the D-Jectro..?
is your gtr bonnet Black as well? looks gunmetal to me
Yeah it is Gunmetal, will get it painted when i get some other bits and pieces done, just dont have the funds atm.
Make sure to post up your dyno result in the forced induction sticky, i'd like to compare against mine as we are using almost exactly the same parts.. 'cept for the d'jetro.
will do mate.
The air flow meters are there to keep the street legal look, but they have had all there insides removed to increase flow.
Here's the dyno graph :)
cheeky bugger.. very nice mate, with the gtr front end it will look awesome.
This is my latest mod to the car, cold air box. Helps keep the hot air out and it also hides my boost controller solenoid :P
I also went out and brought this little kit the other day, just need to find the time to put it on.
  • 3 weeks later...
so.. where does the air go? I can't see any venting to allow flow through so does that mean that it will just be a dead pocket of air around the cooler or am I missing something? Other than that it looks very nice, trying to figure out where and how to mount one in my car.
I have got hold of a R33 front left inner guard that i will cut the vent out of and rivet it behind my cooler :domokun: i just ran out of time.
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
