R32 Gts4 With Rb26
I though it was about time i put something up here about my car.
It started out as a standard GTS4 with only a cat back zorst imported a few month before i brought it in early 2005. first mods were front mount and a set of chrome 18's
I drove around with the car like this for a year or so with no other major mods just a dump pipe, front pipe and a bleed valve pushing out about 160rwkw.
In early 2007 i noticed that my car started to idle lumpy, did a comp test on the motor and found that i had nothing in piston 6. So i decided to go all out and chuck in a Rb26. this is the piston from the rb20
I managed to find a R33 rb26 with 80,000k's with gearbox from Japanese motorsport, i also got some coilovers, strut braces, stainless front pipes and 32 gtr brakes. I also got a Power-FC D-Jectro all installed by Tilbrook Auto & Dyno, the car was tuned by Martin Donnon and made 230rwkw.
Not long after that i got my new plates and earlyer this year i brought a set of 18x8 1/2" Drift teks.
I have now upgraded to R34 GTR rims painted the same gold as the Drift teks and i also brought a GTR interior.
I have now also fitted a GTR bonnet and grill. My next major mods are a set of Garett GT2860-5's, HKS dumps, Nismo pump and Sard 700cc injectors which i hope to have installed in the next week or 2, when there on and tuned i'll post of the dyno sheet, it should be around the 300rwkw mark :cheers:
Edited by DSTROY
  • Replies 46
Amazing work!! love the engine colour, did you choose that or did it come with it?
I painted it myself before it went in, its just spay can stuff with a clear coat, colour is Cyan Metalic you can get if from Super Cheap.
Damn this thing is awesome, a Sleeper and a half!
You couldn't even tell, unless you can recognise the exhaust note and you probley freak the crap out off ppl trying to drag you off at the light.
BTW you said you have an APexi Power-FC D-Jectro installed, but I see you still got the air flow metres in one of the pics... I thought you did not need air flow metres with the D-Jectro..?
is your gtr bonnet Black as well? looks gunmetal to me
Yeah it is Gunmetal, will get it painted when i get some other bits and pieces done, just dont have the funds atm.
Make sure to post up your dyno result in the forced induction sticky, i'd like to compare against mine as we are using almost exactly the same parts.. 'cept for the d'jetro.
will do mate.
The air flow meters are there to keep the street legal look, but they have had all there insides removed to increase flow.
Here's the dyno graph :)
cheeky bugger.. very nice mate, with the gtr front end it will look awesome.
This is my latest mod to the car, cold air box. Helps keep the hot air out and it also hides my boost controller solenoid :P
I also went out and brought this little kit the other day, just need to find the time to put it on.
  • 3 weeks later...
so.. where does the air go? I can't see any venting to allow flow through so does that mean that it will just be a dead pocket of air around the cooler or am I missing something? Other than that it looks very nice, trying to figure out where and how to mount one in my car.
I have got hold of a R33 front left inner guard that i will cut the vent out of and rivet it behind my cooler :domokun: i just ran out of time.
 Share
    • Well I had 2 choices from then on. I either had to (reluctantly) move it on to another potential buyer and take the loss on the chin. Or I stick with it and turn it into a restoration project. I chose the latter. Project Snowstorm began! The frp body kit was the first thing to go. Turns out the original colour used to be silver. The Neo and gearbox were removed, along with the prop and exhaust system before it took a trip to the bodyshop, where I wouldn’t see it again for quite some time due to the pandemic hitting very soon after they took it away. Eventually, progress began and damage assessments made. Even the front chassis leg was in pretty bad shape!     Then the chopping commenced. For these guys it was just usual routine, to me it looked absolutely terrifying!   More to follow as I’m struggling to focus on my screen at 12:45 am!!!
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
