Genuine Jap Wheels-work Meister Vs Kf -volk Black/bronze Te37 Gold Gt-c Gt-n Ce28n Re30- Ssr Sp1 Typec Most In Stock
Hey guys,
I have the following in stock
Rays CE28N Silver-LIKE NEW CONDITION
Suit GTR32 33 34 and Evos
18x9.5 +22
$3200
Work VS KF Silver
18x8 +33
18x9 +34
Excellent condition
$2500
Volk TE37 Black
17x9.5 +12
Tyres bald
$2700
Volk Racing GT-C
17x9 +19
Bridgestone 255/40/17 ~75%
$2700
Black Racing N1 Pro
18x8 +30
18x9 +38
$2100
SSR SP1 Professor-Chrome with polished lips
114.3x5
17x8.5+25
17x9.5 +30
$2500
Volk GT-C Face2 top Secret Gold
18x8 +23
18x9 +25
$3,200
Volk RE30- Excellent condition
18x8.5 +25
18x9.5 +35
Advan S Drive 245/40, 275/40 ~90%
$3700
SSR TypeC- Excellent condition
17x9 +21
235/45 ~65-70%
$2200
Volk GT-N
17x10 +22
$2400
RegaMaster Black-Super lightweight
17x8 +35
17x9 +38
RE01 235/45 255/40 ~60% treads
$2200
Volk GT-7
18x8 +36
18x9 +39
235/40/ 265/35 ~60% Dunlop
$2500
Work Meister S1 3P
18x8.5 +26
18x9.5 +40
Tyres 235/40, 265/35 ~80%
$2700
Nismo LM GT4- light gutter rashes
17x9.5 +12
245/45 ~65% Michelin Pilot
$3000
Note: PRICES ARE FOR PICKUP IN MELBOURNE. INTERSTATES WILL BE LITTLE EXTRA
For more info on the wheels or anything you find on the website please email at [email protected] PM or call 0422 422 344. :(
Thank you
Regards,
Thuy
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
