Hey Guys,
I am looking at getting a new viper alarm installed in the new year but also want a turbo timer that will work with it. I want to be able to give the installer everything so he doesn't have to wait for anything.
I am partial to the HKS range of turbo timers only because I have had one previously but can anyone tell me what ones I can look at that will intergrate properly.
Cheers
troy,
in short none of them do. adding one to a DEI unit is a major pain. especially if its going on your purple thing :happy:
flick me a PM and I'll explain.
Hey mate,
i actually sell vipers and as the previous person said. it's a pain which is true. it's actually advised that you dont add an aftermarket turbo timer to your viper and just use their inbuilt turbo timer. less headaches.. does exactly the same thing. you can adjust it in 5second increments if i remeber right.
  • 1 month later...
Here's how I fixed this issue:
The guys that installed my alarm told me that the yellow wire on the (viper) alarm harness was what sensed if the engine was running or not. They suggested to cut this wire, but after I did, the alarm thought the engine was never on, so it would start arming while I was driving. Obviously this wasn't a practical solution... So I busted out my voltmeter. What I found was that the yellow wire has 14V running through it when the engine is on, and 0 when the engine is off. I needed to find something that was 14V when the engine is on, and 0 when the key is removed and hook that up to the yellow wire input of the alarm. I tested the wires in the TT harness, but they didn't change when the key was removed, only when the engine turned off. Then somehow my eyes rested on the parking brake wire...
Testing showed that the parking brake wire was 0 when it was pulled up, and 14V when it was released. If I hooked that up to the yellow wire of the alarm, when the parking brake was pulled, the alarm would think the engine had been turned off, and would activate as soon as you opened and closed the doors (I have auto-lock and auto-activate on).
So I ran a wire from the gray wire of the parking brake sensor to the yellow input of the alarm, and it works perfectly, assuming of course that you pull the hand brake every time you get out of your car... The best thing was that the wires I tapped into were in the alarm harness and the TT harness so I didn't have to touch any factory wiring...
Hope this helps...
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
