If you are only using the drive to store movies & <cough> porn <cough>, then I wouldn't bother with it. If you are using the drive for both OS & storage, then I would divide it into a small partition for OS & the larger one for you other *stuff*. Just to keep it more "organized"
Either way, don't over partition a HDD, as it will slow down performance (keep it at about 3 max) as the head has to travel all over the place to look for the relevant stuff on the disc.
PS: you do realize that you mentioned porn twice right? :action-smiley-069:
ye dont partion... no point.
defrag it once every few months if it see's a fair bit of delete/write use. otherwise dont bother really
Dont use the windows one, there are better ones you can grab off the net. Faster too usually
thanks fella's.
Ive accumulated a fair bit over the years they become sentimental after a while so I find it hard to delete them hence the porn X2..lol even though i dont watch them I like to know that they're still there.
when you mentiond defrag ash i was, eek on using the windows one. would take forever. any in particular you would recommend?
+1 for what Mayuri Krab said
if ur gonna put a OS on there id spare 30GB for vista (if u use vista) and leave the rest for ur porn (and movies :()...
for defrag, there is a program out there called O&O Defrag Pro v10.0 which is very good... ive used Diskeeper in the past and IMO i think that O&O is better... but you can still try both to see what u like...
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
