My other half has been using my skyline this week, cus he left his keys out at work (works 2 hours inland)...
Him and his mates bought some air horns, the type you use with that gas stuff..
He left them in the car, in which the car sits outside in the sun all day. Next thing he hears this huge BANG!
Due to the amount of heat, the cans blew up inside the car, and smashed one of my windows.
I dunno what the window is called - but now i need a new one!!!! So anyone that would have one, im keen to buy! It's a R33.
So guys, please don't leave aeresols, or even alcoholic cans rolling around your car. I've learnt it before with alcohol, as someone left a can of jim beam inside, and it exploded.
Took forever to clean!
Cheers Karina
https://www.sau.com.au/forums/topic/250701-dont-leave-aerosols-inside/
Im making him pay for it.
He's been a bit unlucky lately. He put up one of those shade things, which were held down by 1 brick on each corner.. the strong winds flung is off his r32, and when it landed all the poles scratched each panel, + his brand new if a month old front bar. Did it a couple times..
*sigh*
ahh yes
karina phone or email niswreck and get a price on one off them, dont think it will be cheap but
its not something you see floating around here that often but u might be lucky
no u cant steal mine :(
good luck with it. Let me know how u go
Did you have factory UV glass? If you did then it could be very hard but it looks like you don't from the pics...call some glass repairers and see how much the rear quarter glass panels cost...
New windscreen (front) was $250 on my R33, at least it wasn't the rear window (with the demister) :P
Had the same thing happen to a can of deoderant in my girlfriends car, it was sitting on a CD at the time and the CD got blown into about 40 peices, was pretty funny. Other than that, no mess, apart from the car smelling like Lynx :P Must have been one hell of an explosion on yours, lucky no one was inside! :)
*sigh*
Damn, expensive lessons....nothing to do with luck though. Heatstroke affected decision making maybe.
Good thing it wasn't whipped cream or cheez whiz, now that would have made a mess.
A clip across the ear is required I think.
Jeeeezzz, i have one of those tyre sealant and inflator cans.........can only imagine what that would do to my interior.
please dont use that on the 34 gtr johnny....
i keep one of those tiny deoderant cans in my centre bin... no probs as of yet :D
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
