Hi guys selling my front end nothing wrong with it, just wanting to upgrade too R34 front.... all panels are black.. Items located in Melbourne can ship interstate @ cost!
N1 GTR Head lights $300 for pair or nearest offer
Clear indicators with orange side lens/bubble $90 for pair.
Front Guards perfect condition right and left $270 each or nearest offer.
Gtst bonnet has slight dent in it wear someone sat on it $70 or nearest offer.
Type M side skirts Black $170 for pair.
R32 Rear pods $80 for pair.
R32 Rear bar $80 or nearest offer.
R32 Rear spoiler $50.
Tomei Gear knob $80.
Kenwood head deck mp3/cd player $50 or nearest offer.
Pioneer master unit with controller and installation / user manual $600 this unit controls dvd player/ Tv / head unit & playstation with enough wire to run to rear of car.... this is cheap as unit retails for $1800 and is only 5 months old!
also have the thing that goes under or above the head unit that is plastic and holds things dont know what you would call this thing make an offer on it if you want it thanks guys for looking happy new year!
I can be contacted on 0424 664 134 in the chadstone area
https://www.sau.com.au/forums/topic/250709-for-sale/
  • 1 month later...
HEY GUY's i been getting a few replys in the last 2 weeks from the tread
so if ppl are still interested yes everything is still avaliable accept for the gear knob, head deck and master unit witch i have sold already prices are all neogotiable... please dont call from private number thanks
https://www.sau.com.au/forums/topic/250709-for-sale/#findComment-4457150
front bar is a fiberglass GTR copy with-out the lower lip, and has the middle cut out for larger intercooler and it has been sanded back and primed in black i did not think anyone would have any interest so i did not bother mentioning it
if you are make an offer
https://www.sau.com.au/forums/topic/250709-for-sale/#findComment-4458265
No i dont....
waiting on money a transfer for the indicator's and the rear pod's they are practicly sold!
the headlights should be sold tomorrow just waiting to meet up with someone!
also got someone else interested in the right hand side front gaurd, the side skirts and rear bar but there not 100% yet
https://www.sau.com.au/forums/topic/250709-for-sale/#findComment-4460880
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
