  • Replies 49
Popular Days
Originally posted by SmoothLine
:werd:
Some of them run a lil rich, good thing to tune them up and lean them out... Leaky diffs don't seem to be a huge problem from my experiance...
I haven't had the experience of leaky diffs, starying rear ends. Thank Christ.
The can be leaned out over time though during the running in period and good tuning. If it continues to run rich, you gotta let it go and trade up.
The headlights generally are a problem though unless you don't mind carrying a bit of extra weight. The race spec with less weight generally take out things like xenons but it's simply a design flaw as I don't think they were designed to drive at night.
This is so so true.
I believe the headlight issue is made up for in both the styling and overall appeal of a HPI
I went for the long wheelbase european luxury model myself.
Sure, it can give you a few headaches, and is sometimes expensive to run (requires premium fuel) - but a true drivers model that, in either sport or cruise mode, can give you hours of enjoyment.
Shape is quite timeless, so sometimes hard for others to pinpoint how old it is - and is actually younger than you'd think. Only downside is that when left alone, can attract a little too much of the wrong type of attention.
Lots of extras and just enough room in the back. I'm told the headlights are in line for an upgrade (as part of the used vehicle warranty) so I'm waiting on information from the factory about the extent of this. Not unhappy with their current performance though.
And the winner of the Best Application of Car Lingo to his Bird, award goes to James.
Mate, that was a champagne bit of commentary. Not only did you show expert knowledge of the car industry catch phrases but you applied them perfectly to your current "transport"
I am thouroughly impressed by your commitment to convey as much information as possible without actually stating the obvious.
10 points mate, a performance like that can't be faded.
:burnout:
Mate, I don't give a fat rat's crack whether it was off topic or not. My threads are for my amusement only so if its funny, post it. And that was hell funny. I don't think it can be topped actually. I think you should show the post to Louise and let her bask in the pride as well.
I'll be starting some new threads soon when I lose interest in this one. Don't worry about keeping them on topic. As long as they stay funny unlike that damn Vic Wasteland.
When I get bored with the thread, I'll ask the Mods to close it.
( see the "Just Ask Wardest" thread for example )
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
