Priorities... Same getting married in October + gotta save for the all important honeymoon hence my engine build is off, so I'm focussing on suspension to make it quicker ^_^ hey evil weevil what sort of suspension mods you got? Get decent traction or what?
  • Replies 56
Forged internals and wind up the boost as ive done just about every thing else.
Brakes-done
Suspension-done
Bolt ons-done
Remove stupid 400r bar and replace with standard bar to give me that extra 25mm so i can get into my driveway-done
252kwatw at 14 psi now on a conservitive tune but with forged internals and more boost with a nice tune after run in = ???????kwatw
Im hoping for 1 bazillion & 11kwatw
GO RB25 GO
SMOKE THEM BAGS.
Take it to Eastern Creek for some laps and a couple of 1/4s.(hard as coilovers so lots of wheel spin i thinks)
Hope i dont break it to quickly
Also buy a old Vaiant and rebuild it, ie VF-VG, my missus said i could do it, but she said it cannot bounce around when i drive it because it make her boobies jiggle, guess that means soft suspension.
Work to make her pretty too.
19" GTC rims sitting here will be matched with tyres and mounted on!
JJR bellmouth will be bought and mounted once they open - my split dump will be for sale too btw. CES OPTION.
I hope to mount a full body kit to the car - z tune for GTT but unsure if this is still avaliable.
Drop it on its ass and enjoy it - may look into sway bars as I feel it still moves to much on hard cornering.
Happy NY!
new computer, boost controller and tune on monday.... bring on 500hp!!!!
then in lyk a month or 2
sway bars, new slotted rotors all round,braided lines, r34 gtr seats, short shifter, carbon mirrors, bonnet, wing blade, b pillars, radiator air guide, series 3 gtr lower lip and sum other stuff i cant remember atm
Sh!t load of work going on the government should get the cops off our asses due to the amount of money we pour into our cars hence helping the economy which at the moment is a bit fcked, looks like most of us are in the same boats, every bolt on engine part done all we can do is keep upgrading haha
Hmm, I got a voucher from my oldies and my sister for Xmas, so I think that's going to go towards an EBC. Other than that, here's some things I'd like to get done to the wagon over the year, depending on available funds:
  • priority #1 - get the air-con working again ASAP as it hasn't worked since fitting the PFC (long story short, there was no PFC made to suit a Stagea, so there are a few gremlins to sort out);
  • get some GT-R seats and re-trim the rears and door cards to match;
  • get a rear wing, probably just the regular Stagea one or maybe the 260RS version;
  • re-do the stereo - new head unit (probably a single-DIN DVD player with reversing camera), replace speakers, add amplifiers and a sub, and sort out any rattles;
  • get some engine bits coated and maybe try and tidy up the engine bay in general, which may hiding some of the wiring;
  • upgrade brakes to R33 GTSt/R32 GT-R units front and rear, with braided lines - should make it much easier to replace pads when the time comes;
  • replace turbo (if it blows) with a GT-RS or something similar with good response, and get some more minor work done for more power and response overall...
- get my motor sorted
- fit my new plenum, injectors and my ebc
- tune
- sort out my rear suspension + tyres
- new front bar + respray the car
- FINALLY hit some track days
- get into the 11sec 1/4 bracket
I've been thinking of a double din DVD player with gps but I get put off everytime the gps images look crap don't wanna invest 1k for a pioneer one when an eBay 1 for 500 will do the job, some look real nice but I always end up putting it off
Buy my 1st car, R33 GTS-T (Black, Series 1 pref. Type M)
Install Turbo-Back Just Jap Hyperflow exhaust with an extra mid muffler
Install Hybrid Spec RS Intercooler Kit
Install Turbosmart Dual Port BoV
Install Just Jap SR3 Style Seats
Install Boost Gauge
Install Aftermarket Suspension (slight lowering)
Install aftermarket ECU (most likely a piggy back E-Manage for now)
Maybe Purchase and Install Speedy Cheetah's/Volk GT-C's/Starcorp Racing Fusions (19")
Thats bout it for L-Plates and P-Plates whilst I save up for the big build (see plans in newb intro)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
