well lots really...
1. get the defects cleared...lol
2. pay the defect fines...ouch! $400 total
3. new drivers seat or all GTR seats
4. fix and finish my tune...hire dyno or speak to guilt toy...
5. fit new wheels
6. replace intercooler piping or change to greddy plenum, not sure yet...
7. get car engineered so 100% legal...that way the cops can suck my balls!
  • Replies 56
Leather retrim for the GTR seats(or just buy 1 bride for driver's side.
Leather retrim for gear and handbrake boots
Respray the dash and other interior pieces to suit the new outer respray.
Get rid of the stock plenum and fuel rail, not sure what to get yet though.
Fit my clear cam cover
Fit my rollcage(rip out the rear seats)
Harnesses for both seats
Buy a new front strut brace
Camber rods
Carbon fibre bonnet
And still deciding wether or not to two tone the car, black roof, cf bonnet, cf wing and bayside blue body
Probably more but that's the main things
ummm
1 - replace my motor
2 - oil cooler
3 - fix up the paint on my front bar
4 - put car on track :D
that's all i can think off
You forgot line 4!!!! :D
As for moi..
1 - Brake Pads
2 - Braided brake n clutch lines
3 - Bigger radiator
4 - Oil temp sender into sump
5 - Camber / toe arms fronts n rears
6 - Lifters
7 - Retune
And then TRACK IT!! :D
In 2009 ill look at selling my S4, its lucky to have covered 300km in the last month...
the bike has done almost 1800km in the same time...
Ill prob buy something cheaper, smaller but still quick for those rainy days or to take my mates around in......
GTiR!!
-new lights
-fix up damage
-get large show stereo sorted again
-front entry plenum
-new turbo
-hope the engine blows towards the END of the year
-ENJOY IT!
probably in that order too
After winning the 30 Million tonight buy a few R35's
Seriously tho
1. Get my GTR out of CRD!
And then
2. Drive it (pahleeze Nissan gods)
3. Purchase and install SK suspension kit
4. Upgrade brakes
5. Learn how to drive it to the edge....................... and back again
6. Become invisible to 5_0
7. Track days, hill climbs and a few Qtrs
Dagr81 just better suspension for the track, what I've gotnnow is good just needs more adjustment and tweaks, also I'm also looking to buy house and I'm getting married 2010 also!!!
SAU nsw mass wedding! Haha so you got mostly standard bolt ons in terms of power production?
Ok update for me
Spend more time doing diy's
Start doing my own oil changes to save coin
Learn to install sh!t myself i.e. Things like sspension arms and gauges which recently cost me $500 to get installed (500 bux is like new set of conrods pretty much!!!)
You forgot line 4!!!! :P
As for moi..
1 - Brake Pads
3 - Bigger radiator
6 - Lifters
7 - Retune
And then TRACK IT!! :P
lol
okok
and YOU forgot line 8 - buy wagers lol
I might finally install the Power FC i've got sitting around so I can fcuk off this stupid JDM piggyback, maybe I'll give the dirty SR a set of HKS cams while I'm at it..
and other than that I'm in the process of acquiring skirts/pods/front lip and then getting bumpers repainted, and refitting my 17s
oh and I'll go to heasmans to get the suspension readjusted as dori dori spec is proving a handful on the street
not spending too much $$ on her as I got other things to do (overseas holidays > car)
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
    • Well, yeah, obviously. But then you have a turbo with 270kW "design", meaning it will have the higher boost threshold and lag of a bigger turbo, but only doing the work of a smaller turbo. That's the suck. That's actually exactly where I am right now, because my stocker exploded and I got Tao to do a highflow for me. I got a low pressure actuator on it and don't push it past ~10 psi or so, where the stocker was being run at ~12 psi. it makes a little more power than the stocker did, but it lags like a bitch. But, if I run any more boost it starts to ping and the ECU goes into panic mode, which cuts all the fun, so it clearly needs to be tuned. But, until such time as I (which is not I, it's my bro-in-law) can actually get the dyno working again, and get some injectors, and do all the swap over of those and the R35 AFM, I can't attempt to use the turbo the way it really deserves to. So what I have now is something that drives worse than what it did before it filled the cat with little pieces of turbine. I will tune it eventually, and probably only push it up to ~250-270 rwkW, which is pretty close to the max for that highflow anyway. I would imagine that by getting the tune right, and with newer betterrer injectors, we can probably make the boost come on a little earlier than it does now.** And if I do not think that the top end reward is worth the low end sacrifice, I will sell it off and convert to a G30, because the smaller ones of those come on boost very nicely on a 25 and make more power than I realistically need or want. The only reason I didn't do it at the time the turbo blew up is that I wasn't ready to sink a lot of money into an Artec manifold, reverse rotation turbo, the AFM and injector upgrade that would have been immediately compulsory, and the dyno was being problematic.*** It was easier and faster to just put the highflow on. And then, as I mentioned in an earlier post, even that is not "easy", because Tao's highflows use a shorter core than the Hitachi, so the compressor housing moves backwards in the bay, necessitating that all of the pipework had to get modded. ** And maybe just maybe, check the valve clearances and put new shims through, because I have recently seen firsthand on another motor that sloppy clearances on the shims can cost a lot of effective timing and lift and really slow an engine down. 3S-GTE in a Caldina got new shims, closing the clearances from just above the max to right down near the minimum, and it is a massively different car to drive. On boost the better part of 1000 rpm earlier!
    • ooooooh so this is where they get posted  Was at a wedding that day anyway, but the next one I will be there for SURE.
    • @PranK, why do we have this restriction? Because photos are the first thing that gets asked of new people on the forums. Do the spam bots post photos if allowed?
    • How do you rate the clutch @joshuaho96? Sometimes I wonder whether it's genuinely very driveable or whether I just feel that way because it cost a good chunk of money. Most recently when seeing the guy at the tyre shop struggle to move the car...
