Make/Model:
Mitsubish Scorpian GL
Year:
1983
Kilometers:
85,000
Car Specification and Mods:
2.6L 4 Cylinder Engine (JAP IMPORT) not the Australian made engines which are crap
5 Speed Manual
Holley Carburetter (180 dual throat, mechanical secondary)
Exhaust (2 inch after factory manifold)
Larger Sigma front anti roll bar
Manual gearbox out of GE Sigma 1850cc
Lightened standard flywheel
Modified tailshaft (to suit gearbox)
Welded center in differential
Firmer (and cut) springs
The tops of the struts have been turned 180 degrees to give slight negative camber
Harder four wheel drive compound front brake pads (Bendix)
Bonnet is shaved and held down by four metal pin-like supports on top of the bonnet
Has a battery disconnect turn-key complies with CAMs rules.
Asking Price:
$3000 cash, make an offer.
Brisbane
Contact Details:
Private Message
Other Comments:
This car is really fun to drive, love kicking the rear end out the side its fantastic. Engine is in top notch condition, the car has been so well looked after when I bought it, haven't used it so its still in good condition engine is kicked over and run every 2 weeks.
Comes with spare gearbox some semi-slicks may have some spare springs as well.
I do have another seat for the front left with rails however the rails need a slight modification to be mounted which won't be hard or cost much you just need a welder and 5-8mm thick steel plate and drill some holes weld up to the existing rails and wella you have a properly mounted front-left seat.
Do not have the rear interior.
Also comes with fire extinguisher.
Pictures (Click the pictures for larger view)
Edited by airflow
https://www.sau.com.au/forums/topic/250741-qld-fs-mitsuibish-scorpian-driftpig/
Make/Model:
Year:
1983
Kilometers:
85,000
5 Speed Manual
Asking Price:
Brisbane
Contact Details:
Private Message
Other Comments:
If you have something to swap please do show :D
